AtomicHoe094
Atomichoe094
cleveland, OH
had squeaking when using wipers i thought it was the
wiper blades or the wind sheild this went on 4 yrs.
with a clear mind figured i take the wipers off the wind
sheild and turned them on still the sqeak was there.
took the crowl off and seen the linkage was rusty so i took
it apart and greased it no more sqeaking.:party33:
every OBS truck i feel has that problem.. good stuff!!
LI99HOE
Top Notch Tech.
N.Y.
I got the refurb'd gauge cluster I won on Ebay for $14 w/shipping. Checked to see if it solved my fuel gauge problem.... which it did.
Soooooo..... I pulled apart both clusters, and replaced my fuel gauge meter with the one from the refurb'd cluster. Changed over the new clear plastic lens that came on the refurb'd unit to my cluster. Reassembled everything. 45 min. job, and now I have a properly working gas gauge again w/no "Hummingbird" effect.
DefendHawaii
Snake Eater
Kahala HI/ Seattle WA
Drive back and forth between the cabin and Lowes about 5 times and burned an entire tank of gas. I hauled 25 sheets of plywood and bunch of pressure treated 4x4s and other stuff up. Going now to pick up some stuff from a feed store since I can't find large aluminum tubs anywhere else.
AtomicHoe094
Atomichoe094
cleveland, OH
Nice! thats cheap as hell too!
LI99HOE
Top Notch Tech.
N.Y.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
40 miles into to my trip to Mi. Something decides to start burning and the first gear starts chattering. Now stuck in Vallejo, Ca. for a day or so while it gets overhauled. Definitely will install vette servo next year now that the tranny will be in much better shape. I believe it will be getting the Transgo shift improvement kit as well. Will give details when I get more info.
DefendHawaii
Snake Eater
Sorry man that sucks.
LI99HOE
Top Notch Tech.
N.Y.
Double ballstastic..... but @ least ya' get to do some upgrades to compliment the tranny work.
retorq
Kingman AZ
SunlitComet
OBS Jedi-Do Good
I had a new delco starter in the truck that I wanted to do because it is so damn noisy so they will change it out while doing the tranny and if needed change the rear crank seal if needed too.
---------- Post added at 03:41 PM ---------- Previous post was at 03:38 PM ----------
Wish I could get them to install my flexalite 280 efans.
LI99HOE
Top Notch Tech.
N.Y.
DUDE!! I'm totally hooking up with those and some white faces ... and LEDS. Happy BDay to me!!
Def do it. I like the white face look on the cluster.
Thats why I had to change out the gauge meter itself.... I wanted to save my overlays.
Oh, and...Happy B'day
EDIT: When you get your white face overlay....if your old overlay uses foam to separate the idiot light sections.....save it, cut out the foam, and use it on the new overlay. The white face I got didn't have this, and the light from the gauges made the idiot lights look like they were slightly lit. The foam stops this...I found out the hard way...lol
Trav1984
bought a blower motor and 2 door handles puttin em in over the weekend
rushr
Illinois
My project for tomorrow.
Current look....
New parts...plus a interior door handle that isn't pictured.
rushr
Illinois
The guy I bought it from rear ended someone last winter. I just picked up the truck about a week and a half ago.
retorq
Kingman AZ
Yeah when I redid the cluster on my GF's Dodge earlier this summer we did that, saved the foam ... been there bfore lol. Where did you get the CF overlay?? Maybe I'll do that too?! Hahahaha
Bday is the 20th ... soon!! I'm heading to Vegas to watch the Street Car Shootout.
rushr
Illinois
So I was impatient and installed the hood latch support, grille, headlights and 6K HIDs tonight. I put pics up later on.
DefendHawaii
Snake Eater
Fog cleared the windows. Drove it down to and picked up last minute things from target and Lowes. Grabbed some new bolts to mount my front plate again. Need to get a set of HIDs for my high beams and do the 4 mod this weekend.
wwiizz
