llllljrlllll
Great info here... Especially for a Noob like me!
hope you can use it.
llllljrlllll, I appreciate your pictorial instructional how to, however please remove/replace "Drum" with "Rotor", thanks good job we need more of these threads. Actually I would like to see a thread just for HOW TO's.
No Prob. If you have questions, you can email me at [email protected]Thanks for this post. I have never done this BUT I feel like I can knock this out!
I was wondering the same thing. Went back and looked at the pictures. Looks like the old pads were probably noisy since they weren't chamfered. New ones should be quieter for the OP since they are chamfered.
FWIW-I would not recommend to leave the cap off of the brake fluid reservoir. Brake fluid is prone to moisture in the air just by leaving it uncapped. Great write up though!
Still on Step 6:
[/IMG]![]()
Make sure all the pistons get pushed in with the c clam
Mine were just under half pad life when I swapped em. They literally felt like they were trying to stop a semi, all the way to the floor to start to stop... Replaced with Centrix rotors and ceramic pads courtesy of rotorpros, and MUCH, MUCH better braking!
A good tip- NEVER push the fluid back into the master cylinder. Always open the bleeder, push fluid out. Close bleeder when back. Then bleed afterwards. Pushing fluid through the master is a good way of ruining the seals inside it.
Also rotors should be machined or re-surfaced when changing pads, ALA the rotor is within specs. The new surface allows the pad the break into a fresh surface, it reduces chances of noises, and pad glazing.
Also, if you are not mechanically inclined, please leave brake repair to professionals. Brakes are a big deal, don't forget you are driving a 6000 lb. truck at high speeds, you could easily kill someone and yourself.
