llllljrlllll
So here it is, Getting ready to go to Las Vegas, and I remembered to change my brakes at 10pm, yes at night, i'm leaving the next day, got the day off, but I got 3 little boys, 6, 3, and a 8 month old, no time in the day. So I did it and took pictures.
Step 1:
Open the hood, since your facing the hood, on your right all the way back, you'll see the master cylinder
[/IMG]
Now there are 2 things you got to do. First remove the cap, so it can breathe,
[/IMG]
and 2 make sure that the brake fluid is at least half way down (in the middle between Min and max) Why you ask, well when you put the new pads, the brake fluid is going to go up, and the last thing you want is this puppy overflowing.
Remember this, they don't recommend to remove the cap, due to the fact that brake fluid is prone to moisture in the air just by leaving it uncapped. Now this is the way I have always done it, but if you feel better waiting till you push the pistons in, then wait till then, and have somebody remove the cap when you are ready to push in the pistons, and put the cap back on, when your done pushing in the pistons, repeat on the other side.
Step 2:
Lets get the tire off, look at the 1rst picture for notes
[/IMG]
Now if you don't know how to change a tire, you got some major issues J/k, just loosen the nuts please, (Do Not take them off)
[/IMG]
Step 3:
Lift points, (1) is where the your tahoes jack goes, (2) is where you would put a jack stand, but i did it the reverse way, you'll see in the picture. Make sure your jackstand is rated for 2 tons, which is 4000 pounds
[/IMG]
Step 1:
Step 2:
Step 3:
