In need of solid H.I.D.S....
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
I recently bought a cheap pair of flea bay hids from : (xENTEC(orangemika) (his **** suxx) two of the four ballast failed i installed everything correctly put them in well ventilated areas and both highs went...my drivers side low only works occasionally and I'm sending them back for full refund.....
anyhow I'm looking to pay for quality instead of being a cheap bastard..
does anyone have any suggestions on brands and places to buy from!?!?!
any help will be much appreciated Thanks!
Tahoewhat
Ballin' on a Budget
TX
ddm. have had no problems w/ any of the installs i have of them. Which is about 6 cars, and oldest is about 3,4 years.
NJ04HOE
Paterson, NJ
DDM for me too! In the past 3-4yrs I've put them in 3 of my vehicles and at least 4 friends with no problems.
Tahoewhat
Ballin' on a Budget
TX
35w in most, but 55w in my gto. but it has projectors.
MrBalll
West Texas
As far as the low beam only working occasionally you may need to install a relay so the ballast can draw its energy straight from the battery since it needs so much right off the bat.
This is the problem with my right low beam. If I turn the truck off then back on after a few second it boots right up, but that's just annoying.
I also have DDM and they work just fine.
edgaranah1
Corona California
I bought from the same guy and one bulb failed he sent another one. but they still suck.
edgaranah1
Corona California
I would of wanted my money back. but its such a pain to take them off and I think I only pain like $54 for them so haha to me
Kfarron1
Latham, NY
I bought from the same eBay seller, one ballast failed and he sent a replacement right out, problem solved, I love my bulb color too, if they fail again I'm going with DDM as others have said...
ezdaar
Chat Troll
Redneck central, Aka Houston
my ballasts are stuffed down below my headlights, by the rubber dust guard thing.
Have bought 7 sets of DDM Hids so far for my and familys vehicals. none have failed.
one particular friend has put them on his and familys vehicals, including their fleet of 7 bigrig trucks... none have failed. other than one that had a power socket issue, it simply wouldnt snap in. A zip tie fixed that..
All of tehse vehicals have the ballasts just sandwiched inbetween stuff or ziptied to other items..
When I get my sand rail, There will be 5 sets going on it alone..
trebor8820
Louisiana
I must be the only one who isn't so convinced by DDM. I've gone through several different HID kits and am currently on a DDM set (55w 5000k hi/lo with 35w 3000k fogs) in my Altima and have had nothing but trouble out them. It might be because I'm using 55w, though... not sure.
Since installing the DDMs (hi/lo kit, relay included) I cannot turn my headlights on if I've cranked up the car already (fogs work fine), or they will flash on, then turn right back off. Also, the bulbs shake on high beams (but are perfect on low beams). I don't know where exactly the issue lies, but I've certainly not been impressed with their performance.
They do, however, seem to have the most rugged and yet slimine design of all of the sets that I've tried.
tucsonlocal
laguna beach, ca
I am running 35w 6000k DDM as well.. i really cant complain, i have had to replace a ballast and a bulb so far, but they have a lifetime warranty so they swapped them out for free. i have had them over a year now, running strong. It helps that i can go to the store and swap out broken ones, but for the price, you cannot beat them..
D Rollins
