Installed McGaughy's 2/3 and have issues
NORCAL SS
SUV SUSPENSION GURU
at this point its prob something with the spindle being machined wrong messed up the sensor reading at times.
I know this sucks but maybe put the stock spindles on and do a turn and see if it still happens if it doesnt then you know its something wrong with the kit. if it still does it then has to be one of the sensors in front.
A
AMG ETR
Unfortunately I don't have the stock spindles anymore so I can't go back (not that I would want to go through that again haha). Last time I pulled the sensors out they were dirty and had some liquid on them and when I put them back in clean the truck was ok the first few turns, so I may clean them again. I think I got some free-all on them while working on getting the old spindles off and might have got some in the holes as well so its slinging up onto the sensors and screwing the readings up.
Evan
55belairtim
you guys are way off theres a techincal service bulletin from gm on this problem.
seems to be more comomn on the 07 modles. its not noticable untill its been lowered
had the same problem on my 07 avy when i first droped it
document id is
1920299
1702043
1672489
from what my local service rep told me is that theres a sensor under the drivers seat that is supose to sense if the vehicle is going to roll over and ingauges the brake, i noticed it on sharpe turns and if you brake at the same time the pedal bobles back and forth. my local dealership corrected the problem and i never had it since then
freyguy
Exactly. And the kit didn't come with anything to install under the seat!
Any links for these? Google was no help.
A
AMG ETR
document id is
1920299
1702043
1672489
McGaughy's told me about this, but couldn't answer of my question of "why did this just start after I lowered the truck if its a GM issue" I haven't gone to the dealer yet as I haven't had time, but I guess its worth a shot.
Do you know if these bulletins are free even if you are out of warranty?
Evan
NORCAL SS
SUV SUSPENSION GURU
the TSB is a toss up after warranty is over. I have a good plug at the dealership here but most dealerships if there is a problem they will relate it to the suspension product.
see if you have a mod friendly dealership if not they will charge you a arm and a leg.
A
AMG ETR
Have a pretty good hookup at a Chevy dealer, just not the closest one so if it was a sure free thing I would just go to my local dealer, but I guess I'll make the hike to make sure all goes smooth.
Thanks!
Evan
NORCAL SS
SUV SUSPENSION GURU
all good keep me in the loop. Ive never had this problem with the belltech spindles but who knows sooner or later I might so more info we have better we are.
Modded
That Guy
Not a spindle issue, not a drop issue either.
I have this problem and have been having it for a bit over a year now. It started the moment I installed 24s and did not get worst with the McG spindle install or the 26s.
When it first started up unitl recently I thought it was rubbing causing the light until I looked into this TSB two weeks back.
NastyGM, Iwaslowr and me have all discussed this issues in the past and all thought it was just minor rubbing issues.
NORCAL SS
SUV SUSPENSION GURU
Yeah ive never come across this at all before or after a drop guess I just got lucky. In his case started after the drop so hopefully dealership will work with him to do the tsb
Modded
That Guy
Well its easy for the issue to go unnoticed because though the ABS turns on when turning sharply slowly the actual dash ABS light does not turn on. You will only know its the ABS because of how the pedel wobbles/feels. Goes away qucik too. The Stabilitrack mainly only turn on when making right turns and it does not make the SUV handle/feel different, the light just turns on.
Doesn't bug me much at al, but if you are under warranty you might as well get it fixed.
Modded
That Guy
I don't think coilovers will effect anything. When I dropped my truck on springs all around I did not have the issue. It started with the 24s and has been the same ever since, even when I dropped the front 3" it remained like that.
GalaxyBlackEsky
BlackedoutLT3
MD
I just installed my spindles as well and have the same issue. I had ground force springs in the front before and never had the issue. Also kinda pissed that my alignment doesn't look right either even after a alignment was done looks like I have to much positive camber. Also it raised the front up about a inch more then I had on my ground force. But the positive it rides so much better.
Modded
That Guy
If you have got an alignment since the spindle install I bet your alignment is perfectly fine, you're probably just too used to the negative camber the GF springs gave you from spring sag. I bet those GF springs gave you atleast a 2.75" drop due to sag.
I'm inclined to say maybe a spindle and aftermakret wheel/tire install can cause this issue. I know its not caused by the McG spindle because people on GMFS with NNBS Sierra's/Silvys don't have that issue, and it's the exact same spindle.
A
AMG ETR
I am the exact same setup as you, McG spindle and 24" slides with the same issue... Mine started after the spindle install as well... Maybe it is the GM bulletin but why is it happening after the spindle install?
Evan
Modded
That Guy
I just found this TSB (pic below)!! I called my local dealership and i'm taking mine in in the morning to get fixed.
General Fodder
