Black bear tune help..
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Im getting a tune in june and i wanted to know if theres anything i should get done or do before getting it so it preforms better and the engine can handle it...btw my 01 Lt is fully stock under the hood so is hasn't been touched..
also how do i know what tune set-up should i go with?
any help is well appreciated !!!!!!! thanks guys
blueflamed03
Oklahoma
Garry,
fuel filter, plugs and wires and clean MAF, if you over 100K.
Get ready, you'll love it :)
Physh1
Get MAF cleaner...don't touch the wires & just let it air-dry...
NGK TR-55's are popular plugs...
Stock wires are good replacements...no need for fancy wires really...
I would recommend getting Vette servo & installing it in your transmission...a trans service would be good too...search 'vette servo' for all the info...cheap & very helpful mod...
Cameron
Physh1
Amazon or eBay probably will find you the best prices on Delco parts...
redemn93
Jupiter, Fl
use the stock delco iridium replacement plug if you want another 100k miles out of them. i dont believe the TR-55 are even a platinum plug. you will spend a little for them but will be done for another 100k.
i used auolite (the other ford OE) plug wires cause thats all the store had. still working fine 30k miles later. someone gave me a set of 9mm taylor wires. still sitting in the garage. i really dont see why i would need them on a stock motor. i may throw them in just cause.
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Thank you guys im going to keep reasearching so I can figure out tge install on this stuff....haven't done anything under the good yet so you know.. all comments are appreciated!
Sent from my SCH-I500 using Tapatalk
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Ive heard bad on them, like mentioned, dont fall for the 'added HP gains', just use ACDelcos or NGK Cam posted.
Will I feel a difference with the NGK's I'm just wondering bc I have never replaced these as this is my first car..
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Also whats the better tune octane wise? I have no clue about this
blueflamed03
Oklahoma
if you can afford the extra bones when you put gas in, do the 93, and run 91 octane, more power.
think of gas fillup, you put in 10 gallons, at $.40 higher, your talking $4.00
pay to play :)
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
what im thinking of is once you go to 91 octane you shouldnt ever switch back to a lower octane..or thats what i have heard...whats the difference in power? AND WHATS YOUR OCTANE TUNE?
TogaPC
Austin, TX
Make sure you fill up with good fuel that matches or exceeds the level of tune you are getting. Both times I've gotten a tune several people had crappy fuel and it makes Justin's job harder.
If you CEL is lit you should have the codes read and fix any problems before the tune.
Check and replace your air filter if necessary.
As stated above clean the MAF sensor, replace your fuel filter and plugs and wires if necessary. Use NGK TR5IX plugs. I wouldn't use anything else except AC Delco OEM replacements if you want your engine to run right and last a while.
If you have the funds maybe invest in a Cold air intake and cat back exhaust.
Replace the PCV valve...it's cheap and inexpensive.
Clean the throttle body really well.
Make sure you don't have any blown fuses.
Basically, Justin is going to base his adjustments on how your engine is running. You want everything to be in tip top shape.
Sasquatch
Orange County N.Y.
pay to play :)
I just wanted to ask if i`m reading it right, You have a 93 tune but run 91 octane? I have a 93 tune and only run 93. With gas prices approaching $4.00 a gallon for 93 here in N.Y. i`d love to run 91 if it won`t hurt anything.
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
This thread is awesome thanks for the feed back but I have some noobish questions what is the MAF and PCV even thought I have tons of post the lingo is still new to me I have only been in and around my car since December. Thanks guys.
blueflamed03
Oklahoma
yes, all we have is 91 available. The computer will sense any detonation if I ahve any and will pull timing accordingly. I can run 87 if I want, it will still compensate. But mash the skinny, and I wont get all the power, unless I had a higher octane in it. So I just run 91 all the time. Course, all I have too :)
canadiandux
