07 up tahoe guys that lowered rear come on in!!!!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Can you guys give me some info on this thread im trying to find out something
1) What rear spring/shock set up are you using?
2) what size tires?
3) What does it measure from ground to fenderlip
4) what year truck?
5) 2wd or 4wd
I know gm used different springs on the back of these trucks just trying to get some info on how low yours sit.
1sikyukon
SFV, CA
2) what size tires?
4) what year truck?
5) 2wd or 4wd
I am running a Mcgaughys 2" rear drop kit on my 2008 YUKON 2WD. It comes with the Mcgaughys coils, and im running factory shocks. I am on 24s so im running 305s. Its a great kit if you are just looking to level the truck out, but if you look closely the truck doest actually sit leveled its leaning a bit towards the back....
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1) MCGAUGHYS 2 INCH REAR
2) what size tires? 305 ??? 24 missing middle number
3) What does it measure from ground to fenderlip?? didnt put that down
4) what year truck? 08 yukon
5) 2wd or 4wd?? you didnt state that.
rosendo192000
1)MCGAUGHYS 3 INCH REAR , 2 INCH spindle drop
2) 305/30/26
3) haven't measured it
4) 07 LS
5) 2wd
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Can you guys measure please before posting trying to get a chart going
KMeloney
1) What rear spring/shock set up are you using? Belltech 3-4/stock autoride
2) what size tires? Stock 20"s
3) What does it measure from ground to fenderlip? 36-1/4" driver's side
4) what year truck? '09 Tahoe LTZ
5) 2wd or 4wd? 4wd
Right now the truck is just too low for my tastes in the rear. So, I'm going to adjust the links and get it up a bit...
AZSCTACO
Phoenix, AZ
1) What rear spring/shock set up are you using? 3" Belltech springs. Belltech shocks
2) what size tires? Before the drop (305/45/22) after drop (305/40/22)
3) What does it measure from ground to fenderlip. Before (37.75") After (34")
4) what year truck? 2007 Tahoe LT
5) 2wd or 4wd. 2wd
Keep in mind of my tire difference height on the before and after measurements
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1) what rear spring/shock set up are you using? belltech 3-4/stock autoride
2) what size tires? stock 20"s
3) what does it measure from ground to fenderlip? 36-1/4" driver's side
4) what year truck? '09 tahoe ltz
5) 2wd or 4wd? 4wd
right now the truck is just too low for my tastes in the rear. So, i'm going to adjust the links and get it up a bit...
275 55 20?
KMeloney
I'll have to go look. No idea what size the stock tires are.
Edit: Yep, 275-55/20.
Sweet_N_Low
5) 2wd or 4wd. 2wd
Your 305/45's wouldn't work with BT 3" springs?
SmithMO
