Engine code P0449
bigblue
bigblue
Beaumont TX
I just got mine back from the dealership. They charged be about $280 to fix the Evap system valve solenoid. They said it wasn't covered under warranty and that only the major stuff like the catalytic converter and the PCM are covered under the emissions warranty. Why it is always a pain in the ass dealing with dealership service centers.
If someone absolutely knows for sure that theirs was fixed under warranty let me know. I looked and from what I could tell it isn't...
this is exactly what two seperate dealerships have told me...i guess it could all depend on the dealership or the service manager...
wheatswake
houston texas
did mine the other day myself, not to bad at all. part was 36 bucks, would be cool if i could get that back if it is under warranty.
bigblue
bigblue
Beaumont TX
Cool where did you get the part from? Maybe a link or something by chance. Where exactly is the vent valve located at? I have crawled under and looked but I have not seen anything really
2 E L O
Omaha, NE
I just had the P0449 code pop up on my '07 with 71k miles on it yesterday. I have a warranty until 75k so I'm sure it will be covered....but a $50 deductible.
I'll probably just let the dealership worry about it....The only other thing that I've used my warranty for thus far is to replace the transmission cooling lines...they were leaking up near the tranny cooler/radiator.
GM Customer Service
Michigan
I am glad to see that you are planning to work with your dealership to have this issue resovled. I would appreciate it if you could keep me up to date with any new developments. Thank you in advance.
Tricia, GM Customer Service.
fishhunter911
DE
Mine has popped this code twice in the last month. I reset it and it stays off for a couple of weeks but comes back. Once the weather gets warm I will be replacing it myself. No reason to pay almost $300 for a $35 part
And 15 minutes of time.
2 E L O
Omaha, NE
No kidding....little ridiculous how much the dealerships want to fix this crap... If I was out of warranty there's no way in hell I'd have the dealership do it. The replacement is very simple....the hardest part is getting the spare tire down. Ha....
blackchaos
can anyone post a picture and maybe some detailed instructions on how to do it? I've had my check engine light on for about 6 months now and i'd really like to just fix it myself if the part is only $35 and it takes only 15 minutes to do.
2 E L O
Omaha, NE
What year is your truck?
See my last post here: http://www.tahoeyukonforum.com/forum/showthread.php?p=284059#post284059
The part number is listed along with a picture of the old and new part. All you have to do is drop the spare tire and the part is right there. Disconnect the electrical connection and the two hose connections, take out the single bolt on top of the support bracket, and then install the new one just the same as you removed the old one. Super simple once you get under there and look at it.
LightningGA
Saratoga, NY
Bringin' this thread back to life
Looks like my 07 Tahoe felt left out and decided to join the P0449 club. Check engine light came on last night, plugged the code reader in this morning and got code P0449. I tried clearing and it won't clear. I thought maybe by small chance it was because I only had 1/8 tank of gas (or less) so I filled up and tried to clear it again. This time it flashed off and then came back on after a second. Now I had no problem filling up as some have said in this thread (or another I read). CEL is the only thing on, my tighten gas cap is not on. I want to get it taken care off asap because this is causing my remote start to not work and up here in upstate NY it's C-O-L-D.
So I'm guessing it's either the sensor or the gas cap. Which would you guys start with? Or am I just better off doing both?
Second, should I get the updated sensor or the original one?
Thanks in advance for all the help guys (and girls). :D
jstutz101
Kankakee, Il
There should be a write up on just getting the spare tire down! What a PITA!!
philcomstock1
Evaporative Emission Control Vent Valve Solinoid, ACD# 214-1680
Does anyone have the replacement procedure or location diagram for this part. I've been under the car with the new solinoid, and can see the emission canister, but don't see anywhere the replacement part should go. Any ideas (or a diagram) would be greatly appreciated.
Phil
D Rollins
