Engine code P0449
bigblue
Beaumont TX
hello,
My 07 with only 48k miles has the check engine light on. I have read the code and it is P0449. I know it is something to do with the emissons/evap system. At first i thought it was the gas cap. But i went and bought a OEM gas cap from the dealer and the light is still on. Does anybody know what i need to do? Is there a fix for this? Has anyone had this problem? I have searched but didnt bring up much results.
Conor
"Bob's your Uncle"
Seattle, WA
This may help Dylan
EVAP System Operation
The evaporative emission (EVAP) control system limits fuel vapors from escaping into the atmosphere. Fuel tank vapors are allowed to move from the fuel tank, due to pressure in the tank, through the vapor pipe, into the EVAP canister. Carbon in the canister absorbs and stores the fuel vapors. Excess pressure is vented through the vent line and EVAP vent solenoid valve to the atmosphere. The EVAP canister stores the fuel vapors until the engine is able to use them. At an appropriate time, the control module will command the EVAP purge solenoid valve ON, allowing engine vacuum to be applied to the EVAP canister. With the EVAP vent solenoid valve OFF, fresh air is drawn through the vent solenoid valve and the vent line to the EVAP canister. Fresh air is drawn through the canister, pulling fuel vapors from the carbon. The air/fuel vapor mixture continues through the EVAP purge pipe and EVAP purge solenoid valve into the intake manifold to be consumed during normal combustion. The control module uses several tests to determine if the EVAP system is leaking.
Large Leak Test
This tests for large leaks and restrictions to the purge path in the evaporative emission (EVAP) system. When the enabling criteria has been met, the control module commands the EVAP vent solenoid valve ON and the EVAP purge solenoid valve ON, allowing vacuum into the EVAP system. The control module monitors the fuel tank pressure (FTP) sensor voltage to verify that the system is able to reach a predetermined level of vacuum within a set amount of time.
Small Leak Test
The engine off natural vacuum (EONV) diagnostic is the small-leak detection diagnostic for the evaporative emission (EVAP) system. While previous leak detection methods were performed with the engine running, the EONV diagnostic monitors the EVAP system pressure or vacuum with the ignition OFF. Because of this, it may be normal for the control module to remain active for up to 40 minutes after the ignition is turned OFF. This is important to remember when performing a parasitic draw test on vehicles equipped with EONV.
The EONV utilizes the temperature changes in the fuel tank immediately following a drive cycle to use the naturally occurring vacuum or pressure in the fuel tank. When the vehicle is driven, the temperature rises in the tank. After the vehicle is parked, the temperature in the tank continues to rise for a period of time, then starts to drop. The EONV diagnostic relies on this temperature change and the corresponding pressure change in a sealed system, to determine if an EVAP system leak is present.
The EONV diagnostic is designed to detect leaks as small as 0.51 mm (0.020 in). The diagnostic can determine if a small leak is present based on vacuum or pressure readings in the EVAP system. When the system is sealed, a finite amount of pressure or vacuum will be observed. When a 0.51 mm (0.020 in) leak is present, often little or no pressure or vacuum is observed. If the test reports a failing value, DTC P0442 will set.
Canister Vent Restriction Test
If the evaporative emission (EVAP) vent system is restricted, fuel vapors will not be properly purged from the EVAP canister. The control module tests this by commanding the EVAP purge solenoid valve ON, commanding the EVAP vent solenoid valve OFF, and monitoring the fuel tank pressure (FTP) sensor for an increase in vacuum. If the vacuum increases more than a calibrated value, DTC P0446 will set.
Purge Solenoid Valve Leak Test
If the evaporative emission (EVAP) purge solenoid valve does not seal properly fuel vapors could enter the engine at an undesired time, causing driveability concerns. The control module tests for this by commanding the EVAP purge solenoid valve OFF and the vent solenoid valve ON, sealing the system, and monitors the fuel tank pressure (FTP) for an increase in vacuum. If the control module detects that the EVAP system vacuum increases above a calibrated value, DTC P0496 will set.
Check Gas Cap Message
The control module sends a class 2 message to the driver information center (DIC) illuminating the Check Gas Cap message when a malfunction in the evaporative emission (EVAP) system and a large leak test fails.
EVAP System Components
The evaporative emission (EVAP) system consists of the following components:
EVAP Canister
The canister is filled with carbon pellets used to absorb and store fuel vapors. Fuel vapor is stored in the canister until the control module determines that the vapor can be consumed in the normal combustion process.
EVAP Purge Solenoid Valve
The EVAP purge solenoid valve controls the flow of vapors from the EVAP system to the intake manifold. The purge solenoid valve opens when commanded ON by the control module. This normally closed valve is pulse width modulated (PWM) by the control module to precisely control the flow of fuel vapor to the engine. The valve will also be opened during some portions of the EVAP testing, allowing engine vacuum to enter the EVAP system.
EVAP Vent Solenoid Valve
The EVAP vent solenoid valve controls fresh airflow into the EVAP canister. The valve is normally open. The control module commands the valve ON, closing the valve during some EVAP tests, allowing the system to be tested for leaks.
Fuel Tank Pressure Sensor
The fuel tank pressure (FTP) sensor measures the difference between the pressure or vacuum in the fuel tank and outside air pressure. The control module provides a 5-volt reference and a ground to the FTP sensor. The FTP sensor provides a signal voltage back to the control module that can vary between 0.1-4.9 volts. A high FTP sensor voltage indicates a low fuel tank pressure or vacuum. A low FTP sensor voltage indicates a high fuel tank pressure.
FYI, you should have an Emissions warranty up to 80K
© 2008 General Motors Corporation. All rights reserved.
bigblue
bigblue
Beaumont TX
thanks conor, so i should have an emmison warranty up to 80k miles? i might take it to the dealer tommorow and see what they say. hopefully they will warranty it.
bigblue
bigblue
Beaumont TX
well the dealer doesnt cover warranty like this....they cover the exhaust and catalytic convertor.
Modded
That Guy
Last time I checked, I think this code is caused from part failure, gas cap failure/looseness and topping off the gas tank at the pump.
Thats all I know.
bigblue
bigblue
Beaumont TX
thanks modded, i have tried the gas cap, next i will be trying to clean the canister/vent lines
David4Jesus
Augusta, Ga
Mine just popped up yesterday too and everyones saying an evap soilenoid by the gas tank and that it has been the same part and a problem on GMs since like 03, Im gonna try to go see my dealer tomorrow I just hit 58k
SLT Kon-Man
Southwest Alabama
Mine was getting the same code about a year ago, turned out to be a bad purge valve, dealer replaced under warranty, no check engine lights since replacement...
Hurlz07Tahoe
Charleston, SC
Im having the same issue right now. I had Onstar read the diagnostic code for me and they say its a bad evap valve as well. Im gonna take it to the dealership asap...
bigblue
bigblue
Beaumont TX
let me know how much they charge you to fix it. i still havent taken mine in to get it fixed. from what i have heard and read it doesnt hurt the engine or anything or make it get worse gas mileage, so i havent really worried about it.
OklabyGodhoma
Normal....er, Norman, Oklahoma
Take it to the dealership and have them repair under warranty. Federal mandate is that emission systems carry a warranty of 80,000 miles....NO time limit. They may try to give you some crap but it's the law. Read the "fine print" in your warranty book.
If they keep giving you a problem ask to talk to the service manager and tell him you want GM contacted to pay for the repairs. I think they will see it your way.
Had a problem with mine at 33,000 after I was out of warranty due to time but they fixed it with no problem under the emissions warranty.
Good luck!
bigblue
bigblue
Beaumont TX
Good luck!
i tried to use that on them, but all the service manager kept telling me was that 80,000 emission warranty covers is the catylatic converter. I am going to find my warranty booklet and see if i can see anywhere it should cover this. If not i may try and take it to another stealership in the area. If by chance you could tell me where the warranty stuff is located in the owner manuel?
Hurlz07Tahoe
Charleston, SC
I just got mine back from the dealership. They charged be about $280 to fix the Evap system valve solenoid. They said it wasn't covered under warranty and that only the major stuff like the catalytic converter and the PCM are covered under the emissions warranty. Why it is always a pain in the ass dealing with dealership service centers.
If someone absolutely knows for sure that theirs was fixed under warranty let me know. I looked and from what I could tell it isn't...
Eickybobby5050
