Just got my amp/sub/custom box in! Opinion needed.
felixgun
Lafayette, LA
OK... So i've been wanting to get a little bass back in my life since I decided to sell my Z71 nbs tahoe WITH the system included (bad idea). So I decided to get myself a little Christmas present it all FINALLY came in the mail... The amp, sub, custom box, and amp kit came in (MINUS the RCA 17' foot cable that I thought was included in the amp kit... anyone got a spare?!) :emotions122:
Anyways,
I got a Kicker L7 10" sub (4 ohm DVC), a JL Audio 250/1 amp, and a custom box from some guy on ebay that Modded sent me the link too (Thanks btw!).
Here are stock pics of all the items... My question is, where should I place the amp? I really don't want to drill it into the car but that might be my best bet. I'm trying to go for the stealth/concealed look so I don't really want it out in the open but it looks like I might not have any other options. Any ideas anyone? I'll post pics when I open up all the packages tonight! and install pics when I get a damn RCA cable!
EDIT: Added new pics of my "stealth" system un-boxing and how it will look in the car.
TnTahoe
TN
amp looks small enough to fit right under second row seat
felixgun
felixgun
Lafayette, LA
Hm... looks like that seems to be the best spot. You guys don't think there will be any over-heating issues with this? So just drill/mount the amp down straight into the base of the seat?
blueflamed03
Oklahoma
yep, my 5 channel is living there, actually, inverted, UNDER the seat :) Not on the floor.
deangrell
Round hole, square sub. I'm going to assume these are all pictures you snagged off the websites and not pictures you took ;)
felixgun
felixgun
Lafayette, LA
Original post had stock pics... I just edited original post with all of -MY- pics.
And btw my goal was to add a LITTLE bass. When the square L7 came out first I had 3 12s on a punch power amp and it hurt my ears. Shortly after I went down to 1 10" L7 with a 500 wat rms amp (Lunar amplifier, local to LA) and it was too much. I ended up selling my nbs tahoe with system included.
I am also keeping my bose sub under my front center console. I realize the handling power of the sub is 4x the amps but I am looking for good clean Sound with deep bass, does that make sense?
---------- Post added at 02:00 AM ---------- Previous post was at 01:04 AM ----------
@Everyone who said to put under my seat-- guys if you look where the RCA/power/ground cable will go, you will notice that there is literally no room to plug those cables in and have my seat down at the same time. It fits right now because the amp is not installed yet but once the cables go in, it will not fit. Any other suggestions?
blueflamed03
Oklahoma
have to move amp to back...pics didnt post originally or I would agree, with RCA's you cant put it there.
stevek
Dallas, TX
If those are the non-auto-fold seats, you can remove that cover and cut/drill as needed.
felixgun
felixgun
Lafayette, LA
Turn it around then. You can cut into what it's sitting on
Turned around it doesn't even sit flush in the spot. Trying to avoid cutting into seats... but that might actually look really clean but it won't sit flush in that spot turned that way.. only the other way...
stevek
Dallas, TX
I mean the floor under the seat... the REAL floor is the same contour as the "aisle"
felixgun
felixgun
Lafayette, LA
ahhh i see.. ok well i'll post some install pics hopefully I can do what you're talking about... If anyone else has any ideas on a good "stealth" spot to put the amplifier, that would be great. thanks guys.
stevek
Dallas, TX
I'll go down and look and make sure next time I'm in one of the NNBS
felixgun
felixgun
Lafayette, LA
Cut a square piece of the carpet/plastic piece so it would sit flush with the rest of the carpet. thanks for the advice worked perfectly.
cwh
I'd step that amp off the floor with a carpeted piece of 3/4" MDF. Then I'd scribe that amp contour into that plastic seat hinge cover. I'd use my dremel and have that amp partially molded into that plastic cover with the wiring concealed.
my 2 cents,
Chris
AdrienR
