Intake Manifold Gasket rubber end seals
malones99
I have been reading the threads about leaking lower intake manifold gaskets, and to purchase the Fel-Pro MS98000t gasket set. My question is that my leak(s) are in the front of the engine not the sides. Looking at the pictures (http://www.amazon.com/Fel-Pro-MS9800.../dp/B000CH0C0Y) there is no gasket for the front or rear. Am I missing something. I was looking at some picts from Autozone.com and there gaskets dont show a front and rear seal either. Are they called "rubber end seals" and where do I get them?
Sepiroth
I am here
Kouts, In
Malone, there will be two lower intake gaskets. These go on either side of the heads. Now in the front of the engine and at the rear of the engine, typically what is used is black high heat silicone.
You simply lay down a nice 1/4" bead of silicone from corner to corner, front to back
Set your intake gaskets down.
Set your intake down carefully onto the mating surfaces making sure not to disturb the newly layed beads of silicone.
Tighten all intake bolts, starting from the middle and working outwards to torque.
blueflamed03
Oklahoma
what Sepiroth said, use silicon, allow to set up overnight for best results, after intake is torqued down.
Sepiroth
I am here
Kouts, In
Ah.
lol @ for best results.
After I was done with the installs, they went back on the road.
The place I worked for couldnt let their trucks down for more than a day.
hapyspaz
Austin
Here is your bolt tightening sequence.
Ignore the 30 ft-lbs torque. If I remember correctly, the 99 models engine calls for...
upper plenum torque is:
44 in lbs first time around
89 in lbs second time around
The lower intake manifold is:
27 in lbs first time around
106 in lbs second time around
133 in lbs third and final torque
I also recommend using a teflon sealer on the threads of your intake bolts.
blueflamed03
Oklahoma
Ah.
yes, I meant AFTER the intake was torqued. Allowing the silicon to set up properly.
Sepiroth
I am here
Kouts, In
Yea, that does seem like a good idea. You can do that. I personally, as soon as the job is done, get her out and drive her, yanno.
foreverfalcon40
If I recall this correctly you need full gakset set and two bolt sets. Manufactuer recomends that when do this mod your order a bolt set.
I lucked out I guess, when I have to re-do my heads. Still waiting for them from the machine shop :(
blueflamed03
Oklahoma
head bolts I agree, but not intake bolts. Head bolts are put under pretty good stress.
malones99
malones99
Friends,
Thanks for all the replies, picts, and suggestions! Can you please specify what type of silicone for the front and rear, and do I need a "sealer" for the sides going into the head?
malones99
malones99
Thanks Blueflamed03! Do I need to drain the oil, I'm thinking not.
blueflamed03
Oklahoma
I would after, just in case anything gets dropped during the old intake removal. Just try to keep the lifter valley as clean as possible.
sparg93
Expedition Tahoe
NJ
I know this is old, but very valuable that torque sequence and pressure...
vsaravia
