Cutting :(
CincinnatiZ
Cincinnati and Miami
So I had my 2/3 drop (on 26's) completed yesterday. The rubbing situation has made me almost hate my truck. its to the point that I dont even want to drive it around town. The interstate is my only escape from the grinding.
SO I want to know what you guys have done to trim, cut, shape, mold - whatever - to your fender wells. Pics would be HUGE
drew
C
CincinnatiZ
PS heres a pic i just snapped with my iphone
jtalambo
I have 3/4 drop with 24s no rubbing at all, but when I had my past 07 Tahoe it rubbed alot because I bought cast wheels with generic not specfic offsets (close but not perfect offset).
NORCAL SS
SUV SUSPENSION GURU
Where is it rubbing? are you runnign 295 25 26?
2drhoeon4s
sit in your driveway
turn the wheel till it is rubbing
look at what it is rubbing on
cut it
Modded
That Guy
Weird how you have bad rubbing. I have a 3/5 on 305/30/26 and +35 offset and pretty much had to pull the wheel liner.
I bet your offset is what is giving you trouble.
C
CincinnatiZ
I think your right - its the offset. I am going to remove the liners and see what that can do for me. If not Im going to have to take it to a body shop and have them trim out the fender. Do you think I will ever be able to get full lock again? I feel like ive lost all driveability.
Tony: I think there 295/25/26 but i still have to go check. The ride is just like stock over the bumps. I love the stance too.
Modded
That Guy
There is no way they are 295/25/26! If they were, it would most likely not rub at all, even with a +25 offset. Probably 295/30/26.
But Pirelli is known to make good riding tires due to the soft rubber compounds they are made of, and the only 295/25/26 is Pirelli, so just maybe it is.
Rad Ride
May I know the tire size, wheel size and offset are you are running? Thanks!
BOSS
The People's A D M I N
Dallas
The offset is usually imprinted on the back of the wheel. It will be a 2 digit number like 13, 50 etc.
B
TEXAS DEMON
with a vengeance
texas
in the front fenders at the very bottom, there is a seam that joins the fender. against the firewall, you will need to flaten it with a hammer or go to bodyshop. but that is where the problem is.
NASTY GM
Nor Cal
If your going to bag it I'm not sure I would use that hit. It cost a lot and it doesn't get it low enough.
jtalambo
I can't see that ever being aligned since the bags never has a constant height.
syndicatesteve
Syndicate Steve
Southern California
it has to be the offset of the wheels. I am completly bagged to the point that my inner fenders sit on the top of the tires, and I still don't rub. Even when I had the McGaughy's 4/5 drop kit I didnt rub, but then again I am running 255/30/26 tires.
NORCAL SS
SUV SUSPENSION GURU
on the 24s i do on the nnbs with djm 3/4 kit (not tb springs) ive donet 24x9.5 38mm offset with 295 35 24 and its been fine.
Jumpshot12
