Edwards1337
- Joined
- Jul 11, 2026
- Posts
- 13
- Reaction score
- 9
Gonna start out by saying I've been chasing this issue for a few weeks now, dozens of hours on forums and online, and checking stuff. Found similar issues, but not this one
I've already thrown every part at it, just to do it at this point
New upper control module
Rear hvac module
3x blower motor resistors
Blower motor it's self
The problem is the rear HVAC fan won't shut off, unless I unplug it or pull 30a fuse under the hood to kill power to the orange wire going into the blower motor resistor.
It will stay on if the rear hvac module, the upper controls, both relays under the hood are unhooked even all at once
I have verified the purple signal wire IS adjusting voltage when the fan speed is adjusted on the upper controls.
I have also verified the temp settings are changing as they should, along with the upper/lower blower positions.
What I've found on my testing is say I have 12.8v @ power/ground at 3pin resistor input plug, whenever a resistor is plugged in I'm getting direct 12.8v at the 2 pin blower plug (even if the motor is unplugged)
Whatever voltage I have going into the resistor is coming directly out of it whenever it is plugged in, even though the purple signal wire IS changing with the control knob.
I've put in 3x blower motor resistors from 3x different manufacturers, I just can't fathom every single one is bad, 4 including the oem one
Rear hvac module
