ChrisW
- Joined
- Feb 2, 2016
- Posts
- 10
- Reaction score
- 11
2008 6.2L Yukon Denali 182K
Replacing factory water pump.
The bolts I removed won't go back in.
They thread ok; I can even start them by hand, get them tight very quickly, and don't want to tighten all the way down.
I don't want to force and strip them.
Even tried without the water pump. Same result, they will start but get very tight just a few turns in. I tried multiple bolts in different holes. Same result.
If I wiggle them a little, I can get them to turn a little more.
But you can still see the "used" part of the thread not going all the way in.
I inspected the threads; they all look ok.
I do notice that the last few threads look shiny.
I am going to clean them up with a wire brush on a Dremel and inspect them better.
I did try to search for this, but didn't find anything.
Also, while I am at it, I am replacing the idler pulley and tension pulley. There were only the top 2 bolts on the tension pulley, but there are 3 holes. Have I lost one?
Any help is appreciated.
Thanks Chris
Thanks Chris
