LSxBakakos
- Joined
- Nov 14, 2025
- Posts
- 57
- Reaction score
- 81
Hey everyone, to tie back into my original post i ended up not being able to install the transgo as to i didnt realize its a FULL kit and the trans had to be dropped versus just vb.
Thankfully a month ago I did a little tune on my buddies 09, mainly trans function but some engine side
Fast forward, last Thursday I had a few hours to play on hptuners. My 4th revisions seems to be my favorite so far. I dont have the laptop in front of me and im going off memory so bare with me lol
Engine side was the basic remove throttle actuation limit below the 2250, brake torque limit, dod/afm disable, power enrichment and some other tables i learned off a tuner
Trans side i did use hptuners,transgo, and a few others to understand what i was messing with.
Oddly enough the stuff I didnt understand id screen shot and chat gpt to understand more about said function
currently
Line pressure is 150, and tapered out the chart a little bit. I think b was up from 215 to 220, the other went from 273 to 280
1-2 is at .20 across the board, 2-3,3-4 are around .33 I like a firm/quick shift, this is just my preference(ive never hated the shift feel of a stock trans more hence why im here)
Revision 4 gets down pretty well with stock ecm/tcm tm, tiny bark on the 1-2 but doesn't feel harsh
Revision #5 I tried to perfect what I did in 4 but more rowdy
i found how to disable ecm torque management,mess with inertia and disable trans tm. After resetting the top 3 adaptives I went, got a couple moderate shifts down before going WOT. Oddly enough shifts part throttle felt worse than before, then at WOT it felt quite violent lol. The small chirp went from that to 2 revolutions of violent drivetrain abuse, so at that moment I pulled over and loaded #4 back in
Saturday I made a revision with just engine tm reduced and or eliminated, and trans side reduced(i believe there was one i had to keep enabled). I have yet to load them in the truck, if anyone has any input im all ears
Thanks in advance!
Ill see if I can post a snippet of the wot run I took
currently
Thanks in advance!
