2020 Suburban Premier w/ 250,000 miles. 11,500$
LSCALADE
LSCALADE
I got to 254k miles and decided it's time to swap the spark plugs. All was good for a few days, and out of nowhere I started getting CYL 7 misfire, and my mind immediately went to a lifter issue, but then I heard the spark arc across to something else, and went to check the plug wire, and sure enough it was not seated all the way down. Misfire gone now. The engine seems to run smoother after the sparkplug change. The plug wires had to have been at least 150k miles since they were super brittle.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Phew!
k_arnold72
Which plugs you go with?
LSCALADE
LSCALADE
NGK Plugs and factory AC Delco wires from Rockauto. It had GM plugs in it and Carfax said they were changed around 209k miles. The wires were suspect since they came apart when I pulled them out and I suspect they were old maybe original. Plugs on the other hand looked fine but I am trying to do a STAGE 0 reset on the truck all new fluids and tune up and then push it to the 400k mile mark.
I need to get some help with a tune since I have a larger intake now and a 3" exhaust and I am sure the MAF and VE can be tweaked some, but I am not brave enough to make the changes myself.
1948Buickroadie
