clandr1
Dallas/Fort Worth, Texas
Installed a truetrac in my escalade. This job turned into a bit of a headache for various reasons, but i was able to get it resolved. View attachment 479755View attachment 479756
I have built probably a 1000 diffs over the years and NEVER had this happen. I was able to get it out super easy, but it still is a kick in the nuts. I was doing my final torque pass and on the last bolt i was thinking, man this bolt feels weird, then snap.
come to find out it looks like my torque wrench went bad and i was significantly over torquing the bolts.
Got new bolts and got that part resolved. I was able to get my backlash to .0045" and tossed it all back together before running out of daylight. Still need to toss the brakes on and button up the cover. But the hard part is done at this point.
View attachment 479758View attachment 479759
Much respect. Differentials might as well operate on magic and unicorn tears as far as I’m concerned.
LsHart
Senior Member
just meguirs compound, polish, and wax with a da
When it comes to DAing, been nervous thinking I would burn the paint. Just one of those things I never really got into.
6speedblazer
Bwahahaha! Translation: I was reading Nm instead of Ft lbs on the wrench
Nah. I had it set to 89 ft lb and snapped a bolt. After I put my digital adapter it read 125 when it clicked over at 89. This thing is like 25 years old, so its probably time for a new one.
Electrickian
Senior Member
I was just messing with you man. I said that cuz I've actually done it myself. Luckily I didn't break bolts tho. And it wasn't on a vehicle either
ncalvo
FL
I'm a noob and it isn't that bad, i think I could go deeper and get more defects out but it is good enough for me. these trucks have so much surface area its a big job definitely don't rush it
clandr1
Currently in the middle of replacing my driver side valve cover with the updated Dorman PCV design. Figured I would snap a picture of the internals before I put the new cover on.
Edit to add: installed a catch can while I was at it.
TheAutumnWind
finally got around to upgrading all the heater core quick connects...
nothing wrong with this set of plastic replacement ones yet... they weren't looking fresh though and I didn't want to wait for them to explode and leave someone stranded.
TheAutumnWind
Starting playing around with a set of headlights. My OEM ones are done and proper HIR bulbs aren't cheap and don't perform well so a retrofit is in the cards...unfortunately these are really shallow housings so we cant do this the easy way. Trying out some NHK Bi Leds in the lows. Ill just run 9011s in the highs- should be plenty of light for the occasional times i need high beams.
6speedblazer
View attachment 480261View attachment 480262
Dont forget the ones for the rear heatercore. Mine crumbled when i took them off.
6speedblazer
Keep this updated, I have been planning out the same upgrade on my escalade just haven't got around to it yet, I retrofitted my Denali about 10 years ago and the light output is WAY better than the escalade HID reflector setup.
I have not opened a set of escalade headlights yet, but my gut reaction is to remove the reflector and make a mounting bracket to go in its place, this would help recess the lights and deal with the shallow housing. Unfortunately this would also force a mod to the high beam setup as well.
TheAutumnWind
Had a bunch of HVAC issues. No rear heat. No front defrost. actuators clicking randomly. Had to disassemble the damn dash to get to the center high mount one behind the radio area. Replaced the front HVAC controller -first dorman replacement screen looked like shit- had to replace that again. Replaced a bunch of actuators-2 in the rear. Did some crack repair on the dash. Still have to put it all back together...
Finally purchased a proper coolant pressure tester to verify there werent any leaks in the rear heater lines, and found out that I had a leak that only showed up above 13 psi. Held just fine below that... one at the throttle body, and one at the thermostat housing.
TheAutumnWind
Damn thanks... i have that open right now too. I didnt even think about those. Same part number?
Edit - found another post that explains this well
ASG-MikeS
