07 escalade 2wd x115 (actually c109) pinout
patrick-ctscv
Hello, I just bought an 07 escalade with 108k miles. Starts and runs well, and while the trans was low when i first picts it up after we added fluid it goes forward and backwards. Can't say i have tried all the gears, i didn'twant to push it so to low oil warnings . I hope it is just bad sensors (low oil and low oil pressure). Scanner shows oil pressure going from 0 to 129ish and back.
Anyway
While trying to diag the lift gate i noticed that the connector the goes from the fuse panel in the engine compartment to parts unknown has some random wires are cut or broke free from the fuse block side of the connector.
I have been searching for a pinout with no luck, so I thought I would ask here. I am sure populated pins vary with options...but I am hoping there is a standard setup....anyway it definitely looks like someone was in the plug. The plastic dividers are missing.
Any pointers appreciated.
Patrick
Welcome to the Forum from NH.
Pics of the truck, please.
Oil pressure going to 129ish??? I've never seen oil pressure go above 80. Get a mechanical oil pressure gauge at Harbor Freight, hook it up and let us know what the oil pressure is, as measured by a mechanical gauge. Cold oil pressure at idle. Hot oil pressure at idle. Hot oil pressure at 2000 RPM.
Post up a photo of the cut electrical wires, showing their location in the engine bay and the colors of the individual wire insulation.
You can find electrical wiring diagrams at www.charm.li .
You mentioned 'scanner'. What scanner do you have? Is it a quality bi-directional scanner, capable of finding deep trouble codes?
P
patrick-ctscv
That is where it has been sitting for ~3 years, and I need to get a better picture but you can see some of the what I think are broken wires. There are floating wires I will get a better picture of when I get home. I **** that last night while trying to juggle a flashlight my phone and the wire loom... :)
Scanner is an older Launch X431 Amazon special. I was data logging the oil sensors. I have seen in posts somewhere else a bad pressure sensor can show that fluxuation, that it happens when oil wicks its way into the sensor and up into the plug end....have not R&R'd yet to confirm if that is indeed the issue.
View attachment 479685View attachment 479686
You've got a decent scanner, so that is good for deep troubleshooting when needed.
When you do take the additional photos, please show that connector at a more distant view, as well, so that we can orient ourselves on just where that connector is located.
P
patrick-ctscv
Thanks for the feedback. I am starting to look through that site and it looks like there is info, just need to find all the c115 references spread across the different pages :)
Update, it is the body side of the connector that I was looking at, it routes under the fuse box which is where I got turned around....
Thoughts?
mikez71
Possibly connects to ebcm. Gray/black wires could be rear wheel speed sensors.
Perhaps they wired in a traction/abs defeat?
No codes?
P
patrick-ctscv
mikez71
C109 - scroll down to the second connector pic..(NP8 RPO code)
mikez71
2011 is as far back as I can find but being the same body style, the wiring is likely the same. If you know how to read these, I’ve found GM up fitter to be extremely helpful.
You definitely want the 07 and/or 08 diagrams. (Available at gmupfitter but maybe in the truck or general directory)
The later ones are addendums to the 08 diagram.
P
patrick-ctscv
Okay still more work to do, but I agree it is likely the C109 connector on the main harness side I have been able to validate some of the wiring so yay....
And to make things more interesting it iis the NP8 connector on a vehicle that does not have the NP8 RPO code (unless someone swapped the glovebox door), and based on VIN (in glovebox) it is definitely a 2WD optioned escalade, but it has a transfer case....????? No front diff and front hubs do not have pass through for the splines.
Maybe it was the end of year parts bucket?
mikez71
Are you saying you have a transfer case??
That is weird! Must have run out of driveshafts or front diffs!
Verify Vin and rpo sticker maybe..
P
patrick-ctscv
Yes Transfer case and no front diff, no switch in cab, front hubs won't accommodate CV joint as far as I could tell
I need to double check VIN on glove box with VIN in front window....maybe the motor went bad and the swapped it in, but wire harness is hooked up to xfer case so I "ASSume" factory....
Thank you copilot for helping create a cross-reference between to two connectors....I am a bit wierded out by B10 engine vs instrument panel (IP pin) but should not matter for me....
FunctionCircuit No.Wire ColorOccurrenceExcept NP8 - Engine PinExcept NP8 - IP PinNP8 - Engine PinNP8 - IP Pin
4WD Low Signal
1694​
GY/BK
1​
C9C9
5-Volt Reference
1164​
WH/BK
1​
C5C5C5C5
5-Volt Reference
1274​
TN
1​
C3C3C3C3
A/C Low Pressure Sensor Signal
204​
D-BU
1​
B6B6C12C12
APP Sensor 1 Signal
1161​
D-BU
1​
C4C4C4C4
APP Sensor 2 Signal
1162​
L-BU
1​
C2C2C2C2
Accessory Wakeup Serial Data
5985​
D-BU
1​
B8B8B8B8
Axle Switch Signal
1695​
TN/WH
1​
C7C7
Battery Positive Voltage
1342​
RD/BK
1​
A4A4
Channel P Encoder - Signal
1555​
BN/WH
1​
C10C10
Current Sensor Low Reference
5077​
BN
1​
B4B4B4B4
Current Sensor Signal
5075​
WH
1​
B3B3B3B3
Current Sensor Supply Voltage
5076​
PK
1​
B2B2B2B2
Encoder Low Reference
1554​
TN/WH
1​
B12B12
Front Axle Actuator Control
1570​
GY/BK
1​
C8C8
Ground
451​
BK/WH
1​
B5B5B5B5
Ground
550​
BK
1​
B7B7
High Speed GMLAN Serial Data Bus +
2500​
TN/BK
1​
A8A8A8A8
High Speed GMLAN Serial Data Bus -
2501​
TN
1​
A6A6A6A6
2501​
TN
2​
B10
Lock Solenoid Control
1569​
TN
1​
C6C6
Low Reference
1271​
BN
1​
C6C6D7D7
Low Reference
1272​
PU
1​
C1C1C1C1
MIL Control
419​
BN/WH
1​
A7A7A7A7
Motor Control A
1552​
TN
1​
A5A5
Motor Control B
1553​
OG
1​
B6B6
Signal High - Front/VSS High Signal/OSS High Signal
400​
YE
1​
D1D1
Signal High - Rear
2221​
L-BU
1​
D3D3
Signal Low - Front/VSS Low Signal/OSS Low Signal
401​
PU
1​
D2D2
Signal Low - Rear
2222​
D-GN
1​
D6D6
Transfer Case Encoder 5-Volt Reference
6028​
L-GN/BK
1​
B9B9
6028​
L-GN/BK
2​
B10
mikez71
I thought escalades were AWD not 4WD?
Possible owner swapped things, that might explain the cut/spliced wires..
Towmaster
