Fuel Tank Skid Plate?
gmartin1215
Glenn
Does anyone know where a skid plate for the fuel tank can be found? I have tried combing the Web and have not found anything yet for the 07-14, or anything that might work with a little modification.
Kinda scares me to have that plastic tank unprotected when going through rocky areas.
mikez71
Flat panel adequate?
Tray style plates look like they would trap a ton of dirt.. Maybe something similar to this...
Dirty looks
I've had no luck finding anything as well. It's surprising that Asmir doesn't offer anything considering their offerings for the rest of the underbody.
Another arts and crafts project. Aluminum.
Dirty looks
Sounds like this is a good opportunity to learn how to weld aluminum!
I'm thinking of bolting to the bottom of the frame rail and some uprights to the bottom of the body on the other side of the tank.
It should be tempered aluminum for strength. 3/8th's?
mikez71
Not my trucks, was just looking for skidplate ideas.
Not sure about that lift accident either, but I was looking for a good underbody shot, someone has taken some here but I can't find it.
Excited to see what you come up with!
gmartin1215
gmartin1215
Glenn
That would probably work. 1/4" is what I was thinking but 3/8"s would be better. Either way, the aluminium cost will punch the wallett!
Dirty looks
That would probably work. 1/4" is what I was thinking but 3/8"s would be better. Either way, the aluminium cost will punch the wallthis?
Just did a little looking, 500 give or take for a 4' by 4' sheet. Might be enough left over for the muffler area.Need to sheild my water tank as well.
Dirty looks
Trail'd. 14 gals. Safe to drink from.
A bit expensive, as everything related to offloading is.
Mounted a pump under there as well.
Open road shower and water heater.
scottd
