2004 Tahoe - left turn signal rapid blnking & stopping.
Icarus
Hey guy's, I have a 2004 Tahoe that is driving me nuts. The left turn signal blinks rapidly then stops or just doesn't work at all. I've replaced bulbs, the pigtail at the front, fuses are good relay is good as well as changed the indicator switch in the column. Please help any advise would be appreciated, thank you.
Welcome to the Forum from NH.
Pics of the truck, please.
As I understand it, your truck has a specific flasher/hazard module, 12 pins. Have you checked it out, and possibly replaced it?
Icarus
Icarus
how’s the hazard switch? Does it do it when they’re on? You can try jiggling the switch to see if it’s the cause. These also had a problem with the flasher module but my guess is the hazard switch.
Hi, thanks for the advice and when the hazards are on the left side blinks rapidly outside but nothing on the dashboard., so I think I'll replace the hazard relay switch next.
Icarus
Icarus
I'll post pics of the truck in a day or two.
Icarus
Icarus
Here's a couple of pics of my hoe. Not perfect needs some work but she mine.
Towmaster
