Dead battery / parasitic drain
kgwmu
Our 2019 Yukon Denali XL has had a parasitic drain that we didn't notice until it got cold and we ended up with a dead battery. We got it back in May/June of 2025, at that time I noticed that the battery gauge on the dash showed the battery was being charged at about 15v.
I didn't think much of it at the time because it fell in the highlighted area on the gauge, but then we had a dead battery in Dec 2025. We initially thought it was just a bad battery, changed out the battery and the battery gauge hovered right at 14v. We had another dead battery, I thought maybe it was the sharkfin antenna, which had a leak or our rear wiper motor, which was going bad. I finally got around to changing out those parts and it didn't fully fix the draw. I did find a couple of things that are drawings power, but I'm not sure how to fully diagnose the issue.
Dash activation video
Battery amp draw video
With the truck fully asleep, I found that something in/on the abs module would activate every 1 minute 35 seconds, I could hear it click. I pulled the fuse for that and the draw dropped a little, then I noticed that on the same time increment the instrument cluster and radio screens would wake up as well. I say wake up because screens would just light up the background of the screen, none of the icons or gauges would appear.
Another thing I did find out, from a GM tech, is that the Seat Memory Control Module (SMCM) could be waking up a low speed LAN bus when temps are below 40F, see doc below. The only fix is to replace the module.
I don't understand the LAN bus stuff at all. I also don't know if these modules are tied to the other two issues that I noticed happening.
Anyone have any insight on a similar battery drain?
Searchable text from photo:
Document ID: 6074038
Condition:
Some customers may comment on the following conditions when the ambient temperature is below 40 degrees F:
• Dead battery/required jump start.
• Slow crank
• Battery low state of charge, and if equipped, Auto Start/Stop inoperative
• IPC backlighting turning on intermittently while the vehicle should be asleep
• Keyless or passive entry/start inoperative
These concerns are not easily duplicated in the service bay or with temperatures above 40 degrees F.
Note: The condition is intermittent and ONLY occurs when the vehicle has been outside overnight or longer and the ambient air temperature is below 40F for extended periods of time.
Cause:
These conditions may be due to a low battery state of charge that is being caused by one or more modules waking up the Low Speed GM LAN Bus. It has been found that the Seat Memory Control Module (SMCM) could inadvertently wake up the Low Speed GM LAN Bus when the ambient air temperature is below 40 degrees F. This condition could apply to all SMCM a vehicle is equipped with like: Driver K40, Passenger K40P, Left Rear K40LR and/or Right Rear K40RR.
Note: Some vehicles without memory seats still could have a SMCM to control a Safety Alert Seat RPO HS1, example vehicle 2021 GMC Acadia.
Big Mama
Virginia
Have you checked your alternator? If the pervious battery was receiving 15v it could be doing the same to the new one.
Bob Miske
I replaced the battery and the alternator, and the situation remains the same. As someone said, if it's in the garage while changing the alternator, it won't do it when I leave the parking lot because of the heat from the building. I had a fender bender last fall, and I thought maybe one of the cables from the battery was pinched between the sharp edge of the fender and the frame, causing a voltage loss. Your explanation sounds better than mine.
@Bob Miske Look up EPM and RVC to learn how your charging system works.
If you make many short trips with your truck, or it sits for a long time between uses, the battery is not getting back to a full charge. The cold weather may exacerbate this condition.
When you bought the truck, the computer system was nursing along a dying battery to keep you from getting stuck. I doubt that the alternator was faulty. It's output is controlled by the BCM.
Big Mama
Virginia
And I can’t recall if your ground cables were brought up.
Bob Miske
I took my 2009 Tahoe in to the dealer because 2 other places didn't help me with the problem. The mechanic explained that the first owner had installed an aftermarket remote start. Somewhere in the module, there was a short circuit, most likely from vibration over the years. It sounded logical, so we went with that. All of the connections were cut to disable the unit. I got 2 new fobs for the ignition. I drove a pretty good distance down the freeway to charge the battery, so all is well.
K
kgwmu
I've had a couple shops take a look at this battery draw issue and they weren't able to figure it out and it's still happening.
Has anyone else experienced or heard of the dash activation like I have shown in the video linked in the first post?
It was checked and it tested fine.
I will have to check the ground cables. I don't think they have been replaced or checked yet.
as noted in the tsb, if a module is not going to sleep it will cause a draw, its just a matter of figuring out which one. may not necessarily be the smcm, that's just one example.
if it is suspect you might be able to unplug it, but that also might not allow the system to go to sleep.
TonyS1203
Condition:
• Slow crank
Cause:
My Tahoe's battery dies overnight. I traced the draw to the Stereo. Now I'm need to figure out what to do, replace stereo seems to be the only option.
gasperfloat
hi kgwmu, did you ever find the cause of your parasitic drain? I have a 2018 Yukon Denali that doing something very similar (dash back lights every 30 seconds, goes ouk in 3-4 seconds and keeps repeating)
That member hasn't been on here in 3 months, unfortunately. To 'tag' a member, use the "@" sign before the username, or use the Quote or Reply (like I did here to you).
Are the key fobs being stored far away from the vehicle when it's not being used?
West 1
I have 2 cars a 2018 and a 2022, when I wash these cars on my driveway with a key fob in the pocket each car will start clicking and lights come on because the key fob is close by. I have to leave the fob 10-15 feet away to stop this silly stuff. The fob being close could certainly keep things from shutting down.
Sisac
I have a similar issue to this on my wife's 2015 Yukon Denali. When I first bought it back in 2021 it came with an AcDelco battery, it eventually died at some point and took it into Autozone to get it checked and charged. Battery charged but it's bad. Bought their Duralast Gold, it lasted a couple of months and started dying as well. Had the battery checked at Autozone and they said it was a bad battery, replaced Duralast Gold #1 with #2, months go by and the battery dies. Back to Autozone and they say the battery is good but low, battery charges. A week goes by and it dies again. This time I take it to the dealership, and they said the battery was bad. They switch out Duralast Gold #2 with a AcDelco #2. AcDelco #2 lasts for about 3-ish years and then it dies on me. Go to the dealership and luckily it was still under warranty, so they switch it out. AcDelco #3 lasts about 2 years when it dies on me too. Truck is no longer under warranty so anything at the dealership is going to cost an arm and a leg. I replaced AcDelco #3 with a SuperStart Platinum (agm battery) yesterday, 7/20. Everything looked fine, the wife turned the truck on earlier today but didn't move it. We're about to go to the store today, 7/21, and the truck is completely dead.
There's no aftermarket electronics installed, everything is stock. Only things aftermarket would be like the shocks and ball joints.
Anybody got any pointers or tips for me? I'm removing the SuperStart Platinum and taking it to OReillys now to see if it's bad or not, it's obviously dead.
Sisac
@Sisac
Plenty of YouTube videos on running parasitic draw tests (use one that doesn't use the fuse pulling method, at least initially).
Update about my comment from yesterday, I took the battery to Autozone to get it checked and not only was it good but it was 100% charged. Installed the battery today during lunch, truck started right up. Checked all the fuses yesterday and everything looked good. Checked the power distribution center that sits on top of the battery, nothing burnt out everything looked good. I saw a video on youtube where someones fuse box was not pushed down all the way and that was what was giving them issues, checked that, all good. A buddy of mine mentioned the Blind Spot Modules in the back sometimes they can get severely corroded so I'm going to check that later today. I'm also thinking about the BCM but my dashboard wasn't acting weird, the whole truck just wasn't getting any power. Any ideas?
PG01
Up here to the right
I know you checked them but unfortunately the battery cables corrode on the inside. Completely remove and clean or replace them. The ground is usually the cause but i would at the minimum completely remove the ground battery cable and actually feel it along the length (ha! thats what she said) and if you feel a hard spot or crunchy spot replace it. It may look fine on the ends but unfortunately the middle is where it corrodes. Clean all ground points while you are at it. Do the same with your positive cable.
a1parrothead
