Interior water leak
95escahoe
I know this is a pretty common issue on these OBS trucks get the water on the pass side mat, its done this for awhile, pulled the cowl and replaced it cause mine was cracked but that didnt really change anything, I blew it all out with an air hose didnt see anything wrong, so i guess the next step is to put some water on the screws under the small part that comes off on either side and see if it leaks there then silicone if it does, any ideas or anything else to look for?
Sent from my HTC One X using Tapatalk 2
95escahoe
95escahoe
ineffective sealant on the windshield.
It did this with the old windshield too had a new one and same problem, it looks to be sealed good
McFizzl
Broke as a Joke.
Fayetteville, AR
i have the same issue. Pretty sure my windshield is letting go of the truck. I get water runs all down the inside of my window after a good rain. Also have water on my mirror and water running down my passenger kick panel.
95escahoe
95escahoe
Mines nothing like that, just a few drips that eventually turn into a small puddle on the pass side on the mat, pretty sure I found my issue and fixed it ill post pics in the am if it works
SunlitComet
OBS Jedi-Do Good
unknown at this time.
are the top and side rubber shields on the glass in place too?
---------- Post added at 08:23 PM ---------- Previous post was at 08:15 PM ----------
also do you see where it gets thru on the inside of vehicle?
95escahoe
95escahoe
Here's how I fixed mine, tracked the leak down to the hvac vent under the cowl caulked the 2 sides I can get too cleaned up around it and repainted it, just need to clean up the panel I had to remove, it was held in with seam seal just use a putty knife then pry it out with a screwdriver found this fix online, gonna test it tommrow and see how it turned out
95escahoe
95escahoe
Scratch that didn't work lol, tested it pouring water down either side and along the cowl it didn't leak well went and washed it and its back its a lil better but still there, who knows lol
bass1775
Maryland
My passenger side leaked after a windshield replacement. Took it back, they resealed it and it still leaked. Turned out to be the cowl. Some of those screws that hold the cowl on, go straight through to the inside of the of the truck. I sealed each screw with some waterproof sealant. Hasn't leaked since.
4myfreedom
Washington, DC
My leak is coming from the center of the windshield coming in through the overhead console. I saw debri in the channel so maybe it did it
95escahoe
95escahoe
Never heard it leak there, not a good spot, mine has be resolved for the most part and when it leaks only a few drops
Bunch of hooey
curious what you found. i’m having the same issue and have ruled out the door seal and cowl drain.
east302
Mississippi
Couple of things to check that have leaked on mine besides the cowl screw…
1. Antenna wire grommet that goes through the firewall under the HVAC box
2. The rubber bellows between the body and the door which has the door wiring in it. Pop the triangle shaped trim piece on the floor kick panel to see where the wires come in and hit the door with a water hose.
3. Damaged plastic sheet on the inside of the door panel. When it rained, water would splash inside the door and leak out under the door panel, collecting in the seal along the floor and overflowing into the cab.
vsaravia
