Water leak
liljdub614
I’ve got a water leak on front passenger side, it’s seems to be dripping down the kick panel from the side access panel on the dash, does anyone know what it could be ?
ivin74
05 NBS Nali
Htown, Texas
How many miles are on the vehicle? Does it do it all the time or just when it rains?
It could be the heater core if it does it all the time.
Check the seals in the cowl area of your truck, underneath the windshield wipers, as that could be a source for your water issue. If it was a coolant leak, you should be able to smell that antifreeze smell.
ARAMP1
Memphis, TN
I had a pretty bad leak mainly on the driver side but it would get to the passenger side every once in a while. I was certain it was the sunroof. I cleaned the drain hoses over and over, I cleaned the seals and tracks and it didn't fix it. Then just decided to RTV the GPS shark fin antenna on the roof. That did the trick.
Foggy
KS
Sounds like the sunroof drain tube on that side.. Can get clogged or even
come apart at the couplings due to age and heat/cold cycling.. That's pretty common
Tupapi
