mikez71
- Joined
- Mar 9, 2023
- Posts
- 3,225
- Reaction score
- 3,993
I wasn't able to remove the clip until I removed the handle!I remember when doing the left rear door I had to undo that plastic retainer as well, otherwise I wouldn't been able to remove the door handle. (front ones are removable without ever touching that plastic goodness)
I unbolted the latch and handle, then pulled the whole assembly upwards until I can slip the handle off.
To adjust the rod, I screwed the rod in/out while the handle was off.
To remove the (rear) rod/clip, I pulled it near the handle opening to where I could get needle nose pliers on the tabs.
How did you remove that clip with the handle on!?
I got my finger tips all over it and no matter how I pushed or tried to depress the tabs, I couldn't.
Tried to sneak a pick behind the plastic tab that holds the rod, and couldn't get a good angle.
I wonder if I had a properly sized metal tube, I could slip it over the cylindrical end and depress the tabs?
