Trying to Pass Smog using O2 extender
Los Angeles, CA
good morning, ladies and gents.
I am having an issue and I was hoping to get some wonderful feedback from you.
After I rebuilt my engine, I am having an issue with my cat on bank one. Can’t clear the code. I swapped out the O2 sensors for a brand new OEM‘s problem still consisted..
So before I went on vacation, ordered the O2 exhaust extenders hoping that this would help me. I installed the extenders on Pre and post cat, i drove to clear codes and now I have a P015D code. my scanner gave me a some freeze frame info and the voltage on bank one Pre cat. The voltage is way off compared to the others. This is the brand new sensor mind you.
So my question is, should I remove the extender on the pre o2 cat cause maybe the culprit was the post o2 yeah cat?
I will eventually change the catalytic converter, but I wanna be able to have the next two years to save up the money for it since these cats on a 13 GMC Denali are $5000
I will post the pictures from the data. See what you guys tell me. My other issue is my OBD two reader shows 44 PSI the car supposedly at the time of the freeze frame was going 44 miles an hour so it just seems like a lot of low pressure. I also know that that low fuel pressure on rare occasions can activate an O2 issue.
thank you for your time. Hopefully someone would be able to help.
j91z28d1
I don't believe the o2 extenders are for the pre cat, they are more ment to slow down the rear o2 signal so the ecm thinks the cat is. working.
on another note, I. agree your trims are all out of wack. by rebuilt engine, can you give some. details? did you put a aftermarket cam in it? any possible exhaust leaks at the exhaust manifolds?
Fernando Escobar
Los Angeles, CA
BOTH banks are calling for LOTS of fuel to be added (lean condition).
Are you sure that the intake tube is sealed properly, and that no unmetered air is getting in before the throttle body? What is the MAF reporting at hot idle, in g/sec?
Any exhaust leaks?
Ill check
it won't pass smog with extenders, if you can get the code to go away you might be able to remove the extender and stick it back in just before you pull up for the inspection..
maybe.....(doubtful)
however you can pass with 1 code pending...
OBSandaNNBS
Known Thread-jacker
The cats are FIVE GRAND?!
Fernando Escobar
Los Angeles, CA
Any exhaust leaks?
Ill check in
CA CARB ones yes.
I got Magnaflow CA CARB cats with Y-pipe (single assy) a few years ago for about $1k, I see that same P/N is near $3k now. I like @Doubeleive 's suggestion.
yes the magnaflows went up and they have a price lock across all authorized dealers which is illegal but nobody does anything about it........
catco is the cheapest (for the 6.2l), walker makes some cheaper but only for the 5.3l
ap/eastern owns both, so between eastern and magaflow and oem is your only options for carb cats
it is illegal to sell them used from a yard but money talks, once in a blue moon you might see some on CL or something
otherwise try to score from someone parting one out from there backyard or something.....
has to be the right year range
federal ones are cheap but won't pass in cali
RET423
Okay you don't mess with the pre cat O2 sensors, pulling them out of the exhaust stream will report a false lean & the ECM will dump fuel like mad trying to correct it
O2 extenders work by pulling the post cat sensor away from the exhaust stream so it reports more oxygen that the pre cat sensor; which tells the ECM that your cat is working well; even though it's not
The pre cat O2 sensor is how the ECM fine tunes the engine, if you mess with that you screw up your engine, the post cat O2 sensor is only there to compare readings with the pre cat sensor to determine if the cat is still functioning or needs replacement; it plays no role in the engine tuning
Fernando Escobar
Los Angeles, CA
Thanks
I removed the pre cat extender and all diagnostics are ckeared and ready to go!
I did a DOD delete on this trck and swore i erased the vlom codes through hp tuners but they show up as permanent codes. My smog gu said keep driving it but im tempted to put the old vlom back in so its plugged in and pass smog alread.
What do you guys think?
Fernando Escobar
Los Angeles, CA
Yeah on rock auto only the cats for the 13& 14 model year will fit in this 6.2. find 5.3 on Facebook marketplace all day.
justirv
Thanks
When you erase codes you reset the emissions flags. You need to do the appropriate drive cycles to clear these flags to pass smog. There are several guides online as to the process to follow to accelerate smog readiness. Evap is typically the longest to clear, and may take up to 200-300 miles of driving. I have been successful in clearing most of my vehicles within 50-100 miles.
Fernando Escobar
Los Angeles, CA
Yeah, they are all cleared now even the evap, but i have the permanent codes from the cylinders that used to be used for the AFM/DOD.
So i was thinking of removing the ls2 valley cover i plaved and reinstall the AFM VLOM to hopefully trick the computer its still plugged in to AFM.
BadDaddy2003
