Ok so I have a 2003 suburban 5.33 flex fuel and I have bad oil leaks my job won't tolerate it. So I got valve cover gaskets And O-rings for the camshaft position sensor and figured I just need to just change them out so I pulled intake cleaned everything up placed what I needed to replace I've installed everything back now and I put the felpro metal gaskets on it that I had bought for a previous truck that I had and it had more problems after a knock sensor went bad never could get it running right so I took the gaskets off of that and hung them on the wall I figured that they would still be good that's the only thing on this truck that came off of that truck and it's causing the same thing is the other truck did I put it all back together I've double checked everything triple checked everything pulled the intake off three other times so far tonight and it's still backfiring through the exhaust. I also had to replace the motor mounts in this truck so I had to take the exhaust manifold off but I've put those back on and I just literally I cannot figure out why it would be doing this unless it's because of the intake gaskets are just warped or bad but I can't for see that that to be happening because I'm barely even was able to get the other truck running when those gaskets were on that other truck I don't know what to do and I'm losing my mind right now.
