DuraYuk
- Joined
- Sep 17, 2022
- Posts
- 976
- Reaction score
- 707
Read the links I sent. Its 10% fuel saved on average up to 26%.I don't think you are understanding my argument. It's about cost-benefit to the consumer.
No one is calling you a name. At least I didn't think so.
Hard to have a discussion when you have the attitude of I'm right, you all are clearly wrong.
All most of us want is a durable product that will last a good long time. And AFM and ASS don't seem compatible with that. AFM, especially early AFM, has definitely proved that out.
If you can demonstrate, long term, that the cost-benefit ratio is there, I'm all ears. Don't forget R&D and engineering costs, usually passed onto consumer in initial cost. I think my OBS MSRP was like $28K. What's a Suburban cost today? Inflation alone can't explain it. No doubt it's a better vehicle overall, but is it the most durable it could be?
IMPORTANT PART:
Other efficiencies like reducing drag coefficient, EGR/Evap, etc, have a great ratio. So does fuel injection. You can only make an ICE so good without negative compromises. There IS a ceiling. If you are worried about efficiency, the solution isn't screwing with the engine to get small gains...it's switching to electric motors. (Long term cost-benefit still in question)
Do you need cost analysis on grill shutters? Low rolling resistance tires? Multiple speed transmissions? Gear ratios? Dynamic fuel management? Cam profiles? Stochionetric efficiencies? Air fuel ratio sensors ?
Or just this?
