guy from norcal
- Joined
- Jul 15, 2012
- Posts
- 705
- Reaction score
- 544
Got it lowered 4/5 drop. New lower ball joints, Upper control arms, Tie rods inner/outer. And put a carven muffler on it.
which carven? any drone sound inside under a loadGot it lowered 4/5 drop. New lower ball joints, Upper control arms, Tie rods inner/outer. And put a carven muffler on it.View attachment 456524
I'm happy with the drone sound, due to my AirRaid air cleaner intake. That's plenty for me.which carven? any drone sound inside under a load
Nice!Got it lowered 4/5 drop. New lower ball joints, Upper control arms, Tie rods inner/outer. And put a carven muffler on it.View attachment 456524
lol, I have a CAI and a Borla sportsman muffler on mine not much drone at all it is mostly passive/aggressive, if you are going up a upgrade at 75 there is a little droneI'm happy with the drone sound, due to my AirRaid air cleaner intake. That's plenty for me.
I have a nice neighbor, that's into equestrian... They have a Dodge Ram..... Their truck is my 6am alarm..... wonderful....
That sound is ridiculous in a Tahoe or Yukon...... A pickup ..sure..... I wouldn't want to listen to that on a long trip.....lol, I have a CAI and a Borla sportsman muffler on mine not much drone at all it is mostly passive/aggressive, if you are going up a upgrade at 75 there is a little drone
but the Carven can be louder depending the model, I have a carven on the Silverado but no drone because there is no rear cab area
meh, maybeThat sound is ridiculous in a Tahoe or Yukon...... A pickup ..sure..... I wouldn't want to listen to that on a long trip.....
( But that sound will mask a 6.2 rod knock )![]()
From my history... my ears PERK UP, hearing a noise like that. I was just joking about that rumble.....meh, maybe
I went to look at a 2016 denali a couple years back at a dealer and I could hear that thing knocking from the moment they started it up on the far back lot and they drove it up front and the sales lady was standing there next to us and I just gave her a "look" and she was like a deer in the headlights she had no words lol. I said something to the effect of and you guys are asking $24k? and walked away
Sounds good, but how does it sound outside? Like if you were passing someone, or just romping on it. How does it sound to someone else? Nice growl to it?lol, I have a CAI and a Borla sportsman muffler on mine not much drone at all it is mostly passive/aggressive, if you are going up a upgrade at 75 there is a little drone
good questionSounds good, but how does it sound outside? Like if you were passing someone, or just romping on it. How does it sound to someone else? Nice growl to it?
Sounds good. I like a bit more rumble/growl. Sounds like you were having fun!good question
I put the same one in mine, it came with 2 set's of cup holders but i only use 1, I am not that heavy of a drinker lolFor who i told i would post this pic for and forgot to post it!.
ya I was getting a kick out of thatSounds good. I like a bit more rumble/growl. Sounds like you were having fun!
I got the carven TR. No drone at all, Has a nice rumble to it.which carven? any drone sound inside under a load
Well, shit. I did a bunch of reading and there were a ton of positive reviews, so I rolled the dice. I put a mix of Duralast uppers and Moog lowers on my '07 a few years ago because I needed the parts same day and that's all the local stores had. The rubber boots on the lowers are cracked and about torn. I would've gone OEM this time but all Rockauto had in stock were the ACDelco gold. They were out of GM Genuine lowers.I would beware of those mevotech, just have seen some reports of the rubber going bad after not too long, I have considered using there parts a few times and did use there end links for a year or two but the bushings seemed to not be all great after 2 years, replaced with a duralast lifetime endlink of 99% identical design.
I decided to spend the extra money and get oem for the rest of it. I am probably going to be owning this thing for quite some time still.
still have another 2 1/2 years payments on the wifes rig before I can even consider looking for a 2020 which is the newest I will likely ever buy
I don't want something that is going to require all kinds of crap work just to get it to roll should it break down, I don't care how pretty they look, the engines are breaking and I can't quit believe that going with 0-40 is going to cure that, no thanks
That's a new one for me. I've never even heard of a broken cotter pin on a ball joint. I will buy good cotter pins from the local Napa, so thanks for that warning.I'll never use Mevotech again. I had their balljoints on my 79 T/A and used their supplied cotter pin which broke within 6 months causing the balljoint to exit the control arm at about 60 MPH. Everything was torqued to spec and checked. They barely had 300 miles on them. The upper balljoint wasnt far off from leaving the chat either. Never Again. Spend the extra money or get better cotter pins.
I had never had that issue either but after I got it towed home and on jackstands the 2 pieces of pin were still in the balljoint. I've done countless front end replacements over the years but never had that happen. Was it a fluke? Maybe but I wont take that chance again. I now have a box of Stainless Pins in my toolbox and will use those now on anything.Well, shit. I did a bunch of reading and there were a ton of positive reviews, so I rolled the dice. I put a mix of Duralast uppers and Moog lowers on my '07 a few years ago because I needed the parts same day and that's all the local stores had. The rubber boots on the lowers are cracked and about torn. I would've gone OEM this time but all Rockauto had in stock were the ACDelco gold. They were out of GM Genuine lowers.
Moog really went downhill. They were the go to at one time. I think Timken is also going downhill.Well, shit. I did a bunch of reading and there were a ton of positive reviews, so I rolled the dice. I put a mix of Duralast uppers and Moog lowers on my '07 a few years ago because I needed the parts same day and that's all the local stores had. The rubber boots on the lowers are cracked and about torn. I would've gone OEM this time but all Rockauto had in stock were the ACDelco gold. They were out of GM Genuine lowers.
I've always had good luck with AC Delco parts from rockauto..they must make them in the good china factory. I agree tho...moog has gone down a bit. If they offer it I'll go SKF or SKP for my bearings now. *** is good but normally only for euro models i've found. Lots of the Rockauto Options are gonna be Chinese built sadly.Moog really went downhill. They were the go to at one time. I think Timken is also going downhill.
