mattbta
Frisco, TX
Nothing major today, just changed the oil and took a sample to send off to Blackstone while I was at it. Figure I can never be too careful with 282k on the motor.
Thought I might have seen you on Rolater last Friday, but the black Yukon I saw looked like it had a bigger roof rack almost z-71 style.
She bit me in the ass again. Drove it to work yesterday morning and 1/2 to work i had almost no brakes. Made it to work ok. Checked it later and found the rear line i replaced last week wasn't secured and broke after being pinched between the frame and bump stop. Luckily I had another line with me--pack of 2. Replaced that, then the line was leaking like a faucet at the compression fitting--what I had fixed last time. Gave up and drove it home with no brakes.
ScottyBoy
Shreveport, La
I parked it, because the transmission will not shift above 30-40mph. I cab actually get it up to almost 70, but only if I rev the engine to like 4500 rpms. I was able to attach least limp it home like that. I am hoping it's not something major. Maybe a shift solenoid or something? It's always shifted perfectly fine, no issues at all. Fluid is changed about every 3 years or so. Its probably due to be replaced, but its definitely not dark or burnt or anything, its still bright red. I called tge shop who rebuilt the transmission about 10 years ago, and they said that they can't even look at it until the 2nd week of April.
This hose was a week old.
It wasn't leaking, it was actually squirting out whenever the pedal was stepped on.
Scottydoggs
NJ
ive had pass rear dead window regulator or motor for ohhhh, say 3 years now lol i bought 4 new regulators 5 years ago on close out at rock auto. (cause dirt cheap and you know one day they all gonna die) bought two new motors for the pass side 3 years ago now. (front pass window is kinda slow) today was the day i finally changed it, i feel super lazy about it now cause it was stupid easy to change. like i know they are not hard, but the backs, my god, to easy.
needless to say, but ive got a working pass back window again.
clandr1
Dallas/Fort Worth, Texas
Edited to add: the pics below were taken BEFORE we did a final tighten/torque of all the nuts and bolts.
Original post:
My truck turns 20 next month. As of today I have 283,030 miles.
Today I replaced the following with OEM GM parts:
rear upper control arms
rear lower control arms
rear track bar/lateral link
rear sway bar end links
rear sway bar bushings
It took me and a friend about 3 hours start to finish. No real issues. The worst part of the job was the 10mm bolts that hold the sway bar bushing straps on. I had to hit them with heat and even then they were sticking and squeaking the entire time I was removing them. I was so worried I would snap one, but thankfully made it through. I used a wire wheel to clean up any bolts that looked rusted/dirty, and I used anti seize when reinstalling.
The old ones didn't look like they were in bad shape. I didn't drive it much after finishing so time and miles will tell if there was a big improvement anywhere. Next up: Front sway bar bushings and front upper control arms.
Malakas
