Aftermarket Radio, No sound from rear speakers (Non Bose, Non Onstar) UQ3
Manon407
Hi Everyone,
I have a 2004 Tahoe with the UQ3 Audio system (No Bose, No Onstar). I installed a new radio, and only have sound from the 4 speakers in the front, no sound coming from the second row. The rear speakers do have sound when the factory radio is plugged in. I've researched, this for hours and I can't seem to find any conclusive fix for my issue. I will list everything I've tried/researched into so far.
1. Looked for factory amp in locations behind the dash, behind the glove box, still need to check under center console and driver seat (but I don't think this system has an amp.)
2. Researched the pink amp turn on cable, but my factory harness doesn't have any pink cable in it.
3. Researched about a second plug behind the dash that has a blue/white or pink wire to turn on the amp. Unable to locate another plug and my OEM radio only has 1 plug, and the antenna wire.
I'm not sure what else there is to do. Most people talk about the Bose system, but I can't seem to find anything on the non-amplified, non on-star system I have. I will list equipment I'm using below.
Radio: https://shorturl.at/qdhfy (Atoto S8G2A74MS)
Radio interface harness: https://www.amazon.com/dp/B01N4WKA7K?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 (GM Class II)
Amp: https://shorturl.at/xymSr (Kicker 47KEY2004)
Wiring is as follows.
Atoto Harness -> (color matched) loose cables on Crux Module -> Crux 8 pin plugged into NON Amplified port -> Crux harness into OEM Harness behind the dash.
I appreciate your help and time and I'll continue working on it while waiting for replies here. I am going to try connecting the "Amp turn on" from the Atoto, to the "Amp Turn on" on the Crux module, but from what I saw, the pin for that on the crux side plugs into nothing on the OEM harness side.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in troubleshooting this area will chime in.
M
Manon407
Sure thing. Here are the connections I have right now.
The CRUX module you list is for Bose. (see the ad that your link shows)
Crutchfield notes that the CRUX CS-GMC2 -- among others -- is the right one for non-Bose, non-OnStar installs.
M
Manon407
I was wondering if it could've been that too, but it says non-amplified so i thought it worked for this. Are there Bose systems that don't have amplifiers?
M
Manon407
Crutchfield helped me out and i feel so dumb lol. The interface box was fine, but the Kicker amp i was using had the amp 2 (rear speaker) gain set at 0 so no sound was coming out. It's all good now! Thanks everyone.
kikeap
