Tuning and dealership issues
ABN45
Wisconsin
So after tuning your truck and then setting it back to stock to say taking it to the dealership for some work on it any issues with the dealership saying it's been tuned or anything like that?
I have an extended warranty on my 2012 Yukon SLT that my dealership thru in as part of a program with Navy Federal Credit Union for Vets.
Don't want anything to come up after I tune and turn off my AFM and then set it back to stock for a dealership fix.
B-train
Depending on the scenario, I can't see it as a problem. If it's only AFM shut off, they probably won't even notice. It's not everyday that computer updates need to be done. They look for codes, etc. One thing toggled off probably won't even show up.
I have taken mine to the dealer more than a few times with a tune installed. no issue they don't even see it.
so unless you are trying to make it go into v4 mode and it has a tune to prevent that then you have nothing to worry about, they don't "check" it
ABN45
ABN45
Wisconsin
I figured as such. Just wanted to make sure was all.
I figured it was the same as my 2015 Silverado 2500HD and it's tuning process and putting it back to stock and being no trace of it.
My plan is to finish tuning my Silverado, then buy the extra auto license and get to work on the Yukon with a custom tune.
Marky Dissod
So after tuning your truck and then setting it back to stock to say taking it to the dealership for some work on it,
1st. You think it's necessary to return your ecm & tcm to GM OE before bringing it to stealership for 'work on it'?
It's yours, NOT theirs. This should go without writing, except you seemed to need to read it again - hopefully this was not the first time you've read this.
2nd. If for whatever reason GM was going to write anything to your ecm and/or tcm,
a dealership would not (ahem) CANNOT read it first.
They would simply overwrite it.
Who inflicted upon you the impression that any dealership even has the ability, much less the prerogative, to read your pcm?
Navy Federal is AWESOME.
IFF the dealership overwrites your tune -
which they will NEVER read first, gottdamnt -
just read their newer revised update of the GM OE files for your vehicle,
then decide whether or not you want to put in your old tune, or apply your tune to the newer revised update.
justchecking
Military
SW Ohio
We have seen instructions to dealers how to determine if a tune (or non gm files) have been installed. What happens if there is a catastrophic failure and the ins company wants a check done? It says right in the ins paperwork no tuning mods (at least mine does). I'm just curious....
Marky Dissod
So am I - I'd LOVE to see these instructions to dealers.
Bet that it involves driving the vehicle, or testing the vehicle itself in some way,
as the dealership has no way of reading out your pcm.
The state emissions check does not read out / download your pcm either.
They can only check checksums and CVNs.
I guess if they wanted to, they could compare your vehicle with your (tuned?) pcm, then compare it to their 'GM OE' pcm.
If your pcm is either much more fun to drive, or much LESS fun to drive, then your pcm is tuned?
(I do know a few people who tuned their pcms for hypermiling purposes.)
It says right in the ins paperwork no tuning mods (at least mine does). I'm just curious ...
There is no catastrophic failure that could possibly be caused by a properly written tune.
If the insurance company is going to use HPTuners or EFI Live to download the contents of your pcm after a crash or something,
why are you still insured by that outfit?
KidWgn
Certified Kid Hauler
St. Louis, MO
(I do know a few people who tuned their pcms for hypermiling purposes.)There is no catastrophic failure that could possibly be caused by a properly written tune.
The warranty companies -- both OEM and aftermarket warranties -- can and WILL read your PCM to see if non-OE files have been loaded if they think they can deny the warranty. They can also check key-cycles since the firmware was loaded. A tune does, and WILL, void your warranty. Whether they choose to look or not is at their discretion.
It has happened to me, and an entire powertrain warranty was voided due to an HPTuners tune still being loaded.
We can all agree that it sucks, but you're regurgitating false information here.
PPV_2018
Molon Labe
U.S.A.
Who inflicted upon you the impression that any dealership even has the ability, much less the prerogative, to read your pcm?Navy Federal is AWESOME.IFF the dealership overwrites your tune -
Look i totally agree with what you are saying in theory, but how we look at it in the eyes of consumers is not the way a corporation all about a dollar looks at it, particularly a dealership or “warranty company” or insurance racket “company” .
What i am saying is, yes, it is your vehicle, not theirs (though since the name on the registration does not matter, the title does — it may actually be the bank or finance companies vehicle, not yours, depending on the situation) , and that’s all fine and well if you own it outright and are not trying to get warranty work done . . . But if you are trying to get warranty work done, then modifications that alter the manufacturing spec of something will most definitely void that warranty IF you get caught.
It’s the same way for everything else. If you alter the operation of an appliance, a firearm, a cell phone, anything other than manufacturer’s spec, chances are you void the warranty.. don’t matter if you “own” it or not..
That being said, no i have no clue if, how, or why a dealer would be able to detect a tune.. but the whole point of my post is if they suspect something’s up and can prove it, YOYO (you on your own!)
KidWgn
St. Louis, MO
A BlackBear tune is undetectable in this generation truck.
I'd love to believe that, but I don't. Not saying I don't believe YOU, I don't believe BB. If the dealership reads key-cycles since the ECM was written, and it's an unusually low number, they'll generally void a warranty.
Now, if BB has somehow found a way around that, I'd be pleasantly surprised to find out how.
Well, all I can say is that I trust Justin and have never heard of anyone having a warranty issue after being tuned by him. I doubt he'd give away trade secrets but you can always ask! @BlackBearPerf
j91z28d1
what did they use to read key cycles? and wouldn't that be over written any time you updates the ecm, even using the acdelco site? Just tell them you updated the software. I recently went thru and updated mine. the tranny had a update. so I did it. if I have a aftermarket warranty and they denied me because of that, I'd be pissed.
on that note, hpt doesn't actually write completely like updating a ecm using acdelco site does.
are you sure you didn't have like full exhaust or a bunch of aftermarket parts and they just guessed it had to he turned to run right and buffed you?
KidWgn
St. Louis, MO
There were zero aftermarket parts on the car in question, aside from 1 step colder plugs with a reduced gap. GM sent me a letter elicitly stating that they were denying my warranty claim, and canceling the powertrain warranty going forward due to the non-factory PCM file. I'll see if I can find the letter.
Marky Dissod
GM sent me a letter explicitly stating that they were denying my warranty claim,
Not being able to tune an ecm / tcm / pcm pretty much disqualifies me from driving that vehicle.
If GM ever did this to me, it'd make me permanently no longer a GM person.
Actually, I'll likely never drive any GM made after 2017 for the very reasons stated above.
That's really phukdup that GM had the gall to do such a thing to anyone generally, you particularly.
Wondering how, specifically, did GM determine that your pcm had a non- GM OE file in it?
Separate from that, it's none of their gottdamnt bidniss ...
j91z28d1
that's wild. I've never heard of that happening to anyone. I used to be good friends with a few different dealer techs back in the car days and no one ever said things like that were done. or even want to waste time on it.
techs are usually not out to get people like that, (they just throw parts at things without diagnostics lol) they just want to get done quickly and services writers are mostly failed used car salesman. they don't know crap.
Marky Dissod
that's wild. I've never heard of that happening to anyone ...
I used to be good friends with a few different dealer techs back in the car days,
and no one ever said things like that were done, or even want to waste time on it.
techs are usually not out to get people like that ...
This particular blue lobster distasteful to swallow, indeed.
Literally the first, only time I've ever heard of such despicable mistreatment.
KidWgn
St. Louis, MO
It wasn't the tech who did it. GM sent a warranty rep out to validate the claim. It was a 2014 Sonic RS that grenaded the turbo seals, and then drank every drop of oil before I could get it off the freeway. Looked like 007 dropping a smoke-screen behind me :rotflmao:
GM warranty rep scanned it, found a non-stock file, and I got a phone call that day. 3 days later I got a certified mail letter from GM stating my powertrain warranty was null and void. What they used to scan it, I have no idea. I looked in my file-folder for that car and the letter isn't in there. I'll dig through the other drawer some day and see if I can find it.
JamesinAbilene
