Valvoline Restore & Protect experiment
the blur
Cyber Space
I'm doing a science experiment. My truck has stuck oil rings, like the TSB says. Burns a qt every 500 miles.
I'm trying Valvoline Restore & Protect without the top engine cleaner job. Just letting the oil do its thing.
3000 miles on the V R&P, still burns oil like crazy.
time will tell, & I'm still hoping.
rdezs
I'm also doing the science experiment, LOL on the neighbors 6.2 engine with 192000 miles. Going to help him with an AFM delete, so we'll see how clean the inside is. He's got about 1500 miles till we dump the second Valvoline oil change. First one came out really dark, so I'm thinking it's doing something.
Marky Dissod
If ethanol fuel is cheap enough where you live, you should try it instead of, or at least blend it with - gasoline.
Let e85 and Valvoline Restore & Protect do their things concurrently.
j91z28d1
if you've got the old style valve cover, you need to update that since it's the cause of most of the oil use. cleaning rings can't solve a hardware problem. but I'm looking forward to your results.
seems everyone is jumping on this. I've got a few k on the first run as well. no issues before had thou. Just for the heck of it. I'll cut the filter open though to see
the real test for this stuff is if someone could. test sticky afm lifters, or maybe atleast take them apart document the amount of varnish and then run a while and re test. be a job for a youtuber. but would be super cool if it could actually keep these lifters clean inside.
Marky Dissod
I believe we did haha.
and donjetman says there's a more aggressive version of it for Cummins diesels. but also more expensive and would probably need to change filter more often
Valvoline Premium Blue Restore. Not sure about the viscosity - 10W30? About $80 a gallon.
Had I a gallon of this stuff, I'd cut 1/2 a quart of it into my engine per oil change.
j91z28d1
E85 is a scam. MPG drops 25% and it costs the same per gallon, if not more.
it is in no way a scam. it is 100 plus octane race gas at the local gas station for less than 93 piss water petrol.
the 6.2 engines love it, it also cleans the top of pistons. now gm didn't spend the money to install a physical sensor on these trucks and trys to do the math off the reg o2 sensors which is mostly a failure. but that's not e85's fault.
just because you don't own a car that can take full advantage of e85, I hate seeing people shit on it. anyone with boost and a flex fuel sensor it's a god send.now if we would. remove the tariff on it and just sell it at the price Brazil sells it to us we would be set.
the 18th letter
Northern New Jersey
I have a flex fuel vehicle and kind of agree with him, wouldn’t call it a scam tho. I have the 5.3 and I run a couple of tanks per year during road trips for the benefits to the engine. E85 costs about the same as 87 near me. I also don’t drive it daily and I hear E85 is not good for garaged vehicles
Not a scam, but a tradeoff and personal decision if your ride can use it. Lose a few mpgs for typically less cost/gal and higher octane. If there's not a significant difference between premium price and E85, then it's probably not a good deal. But it still has its place where it makes sense.
j91z28d1
yes, ethanol/alcohol fuels are corrosive and absorb water. which is a good reason it really shouldn't be in our normal gas. e10/15 in older cars and small engines. plus cause you store over the winter is a hassle.
but e85 in the correct application is amazing. Comparable gasoline would be $10 a gallon or more
donjetman
You nailed it with the valve cover causing the problem (oil consumption) see TSB: https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
@the blur
did you change the driver side valve cover to the new improved design?????
as I said previously, the quik fix is to also do a combustion chamber/piston soak.
Valvoline R&P says it takes 4 normal oil change intervals to cleanup piston deposits. IIRC they don't say anything about unsticking piston rings.
Valvoline does sale a oil specifically designed to clean piston rings - Valvoline Premium Blue "Restore" 10w30, available "only" at Cummins dealers for $80/gal, pt# CA877377GA.
I have used a mix of VPB"Restore" in 3 of my daily drivers. I am currently using a 33% mix of it in our 07 Denali L92 w/200k miles that doesn't consume any oil. I fixed that problem 6+ yrs & 70k miles ago by doing the TSB ds vc & combustion chamber/piston soak over a weekend. I'm using the VPB:Restore" to further cleanup the mess (carbonous deposits) in the engine left behind from the abuse of the previous owner & GMs poor original valve cover design.
https://www.tahoeyukonforum.com/threads/valley-cover-crank-pulley-etc.149036/
and
https://www.tahoeyukonforum.com/threads/sparkies-no-beno.108579/
Marky Dissod
In NYC, 87 octane is $2.89 - $3.19 a gallon, depending on the gas station.
This calculator figures STRICTLY by Miles per Dollar:
Input the price of 87 octane in your area.
In my case it suggests that if E85 is priced over $2.26, I should use 87 octane.
Since E85 also has a mild detergent effect, I'm willing to go as high as $2.49 a gallon.
However, in the 5boros of NYC, E85 is priced too high, so it's 87 for me unless I'm in Long Island.
T
the blur
Cyber Space
I have the 2013. Comes with the revised valve cover from the factory.
Furthermore, why should I run E85 and get 25% less fuel mileage? It's not a race car, it's a daily driver work truck. Suburban LTZ. Horsepower is meaningless around town.
j91z28d1
have you used it to check milage? cause the 25% number sounds a bit official like something you read.
I could be wrong and you did the math thou.
the 18th letter
Northern New Jersey
Because in the long run, it leaves less carbon in the combustion chamber, and even cleans it out, albeit very slowly.
If you use your vehicle less than once a month, I would not use E85, but mine's a daily driver.
I don’t use it much during the colder months but May to September I try to run 2 or 3 tankfuls. Some say it might be more beneficial to run them back to back so I may give 2 a try and see.
JamesinAbilene
