Crank no start issue
Shane5acosta
I just bought a 99 Tahoe 5.7 vortex. The previous owner claimed he was driving around the farm and ran good. He went inside came back out and it was dead.
I tried to fix it bought new battery, spark plugs, ignition coil, distributor cap and rotor. Checked fuel pressure (58 psi). Checked wiring to starter all looking good with solid connections.
Im stuck any advice/ideas?
Eman85
Dead means?? Does it turn over? Compression? Spark?
S
Shane5acosta
It’s cranking but not turning over and I believe it has compression but I don’t have a compression tester is there a way to test without it? And I’m in the process of replacing everything for the spark last thing would be the starter.
exp500
Fuel pressure low. Any codes set?
S
Shane5acosta
What is it supposed to be at I connected the fuel pressure gauge and it read 58 psi when I put the key into the on position and I don’t believe so im on my way home right now I’ll double check
the ignition control module is a classic to fail on these, causing a inexplicable no start or just "died" while driving
exp500
It had battery light on and check gauges light on no check engine light
Tighten battery cables, test battery. Scan for codes or live data if you have a scanner.
Taco
Sounds to me like starter bendix is stuck or a bad starter. You can tap on it with a small hammer a try it and see if that helps it turn over or have someone turn the key to start it and you hit the starter the same time.
JasonW4141
