Spare FPCM (Fuel Pump Control Module) WISE IDEA!!!!
DocDoug
Some dealers will allow an item to stay on open back order status. Some dealers cancel the order if the part is on back order. I have a different part on backorder via a different dealer source and they emailed me and I had to decide if I wanted to cancel the order or leave it in back order status. In this case, I left the part in back order status as the part should hopefuly be available in late January??
I put an order in for a 2nd FPCM via a different dealer, they came back and indicated if was out of stock, but then a 10 days later I received shipping notification.
Again, search around, you may have to pay slightly more for the part and/or shipping, but some online dealers have the part in stock.
Same here. Order cancelled.
"Thank you for your recent order at GMPartsStore.com.
Unfortunately, the part ordered is not available through GM at this time. The part is on an indefinite back order. We have also contacted our network of suppliers without luck."
What dealer were you able to obtain the part?
J
jfoj
GMPartsStore was the first order.
Gateway Parts Online did not have it in stock, but on Saturday they generated a USPS shipping label, so I am hoping they will ship out today or soon. They are in Dallas and I know the temps dropped recently, not sure about snow or ice.
Also check on ebay. I found what appeared to be a dealer parts group listing some on ebay for a decent price as I recall and I think??? they indicated they had stock??
Stay away from the China sellers as this module is supposed to be made in the USA by the label. You could also overpay and get a Dorman unit that is likely a relabled and marked up GM unit if you can even find a Dorman one.
Good luck
J
jfoj
There are a few showing up as new on ebay from US sellers that appear? to be legit and have stock.
PPV_2018
Molon Labe
U.S.A.
Again, my mom's '09 DTS's crapped out without warning last year. My mechanic told me that these units have been notoriously prone to failure for years now. So... Maybe probably?
Good point, but still, making it ~16 years doesn’t necessarily make me think “failure prone”; and it’s possible that the caddy was a one-off. I have not heard of widespread failure of the FPCM on anything other than 21+ T1’s.. that being said, I’ve never heard of this type of part failing on other *makes* of vehicle.. must be a GM thing (it’s possible other makes don’t even have a module like this and that’s why, but I don’t know). But also to that point then yea, maybe probably it would be worth having a spare even for the K2 . . .
I am not really familiar with the K2 platform. I know some of the prior generations did have issues, some with water intrusion into the connector especially if they trucks were used at boat ramps. Some did have FPCM failures.
I also believe this generation required the module to be programmed, so if you do get a spare, test it and if it does not work, get is programmed so you have a functional spare.
Ahhh that sucks big time if the K2’s require programming. Can anyone confirm or rebut this ? Makes it kinda moot since I can’t do in house programming.
KMeloney
must be a GM thing
That's precisely what I was told by a guy who started in Parts and Service at a local Cadillac dealership years ago and who has been in the automotive business ever since.
J
jfoj
Its not if the module will fail, but when IMHO. Either due to component failure, solder joint problems or water intrusion into the connector.
I cannot say 100% that the module needs to be programmed, there was all sorts of info that my 2024 needed to be programmed, but it did not need to be programmed.
I think your FPCM is clearly a different part number from the current models and may be around $100 depending on where you find it.
There are 2 problems when the unit fails.
1. Finding the correct FPCM quickly and easily. Late and night, weekends in the wild, who knows. Buy one and have it in the truck.
2. Programming, does it need it?? Buy it and try it. It will either work or need programming. If it needs programming, you at least have it on hand and can shop around and find someone to program it for a spare, or if you get stranded and have the part, then you just need to find a shop with a more advanced scan tool that can program the module.
In my area, this would be less than a cost of a tow job, plus you would likely need to pay list price for the part, labor to install and programming. Quickly adds up to a $500-$750 job and at least a day or more. Can't even put a value on the PIXXed Off wife!!! If mine fails, it will likely be in the midst of a 2.5-6 hour trip as we take these pretty often.
DocDoug
Good luck
Thanks! I tend to avoid Flea-Bay for car parts. Too many counterfeit parts. I tried Dorman's website a few weeks ago and couldn't come up with a part number for a 2022. It seems they only have modules for prior years.
DocDoug
Thanks! I just purchased from Gateway. I will let you know what happens!
J
jfoj
Gateway just shipped my 2nd module out on 1/6 and I should have it 1/11 depending on weather. I placed the order 12/27 and I think it was showing out of stock when the order was initially placed.
Hope you get a positive update on your order soon.
StephenPT
St. Helens, OR
Just now found this thread - I too bought one of these FPCMs last summer as a spare. It fits perfectly in its cardboard shipping box in the storage tray behind the 3rd row. I've seen enough failures of this module on this forum to know that while it's not a "common" failure, it can happen and the ramifications of being stranded vs a 15min R&R job to replace it is priceless.
As far as programming - it's correct that the FPCM on the '21+ platform does not need it. For reference, if a GM module requires programming, there's a symbol with a wrench and arrows pointing left/right like the climate control module shown below. That symbol is not present on the FPCM and nothing needs to be done outside of removing the old and plugging in the new.
FWIW - I got my FPCM through Rock Auto - it was $30 at the time. Unfortunately it looks like they are on back order right now through RA...
J
jfoj
StephenPT thanks for adding to the thread. Assume the picutre you included was to show the graphic in the lower right of the lable for a version that needs programming.
I would be curious what part number you ended up with from Rock Auto. It seems this FPCM has been superceded a few times. Unclear if the newer part number #13554821 is more reliable or just from a different supplier? While you may not have the latest part number, given it is new, at least if will get you back on the road. Even the part #13554821 may be superceded at some point in the near future.
StephenPT
St. Helens, OR
Yes - the picture I included is a climate control module, just for illustration of the "programming required" symbol GM uses on all of their ECUs.
I received 13554821 from Rock Auto. It's listed as a direct replacement to 5 other GM FPCMs. The FPCM installed on my '22 Yukon XL (built early May '22) is 13537053. This FPCM is listed as being superseded by 13554821.
J
jfoj
I plan on having 2 in my truck. I expect to have to hand 1 out to a family member, friend or complete stranger in the next 12-24 months!!!
DontTaseMeBro
I'm willing to bet that it's already being superseded hence why it's pretty much out of stock everywhere.
That being said, Summit Racing's website states that more will be available Feb. 27th.
I'm going to try my luck with Shea Chevrolet.
J
jfoj
Yep, probably another part number on the way. I still have not pulled mine on the truck to check what is was delivered with, assume the 13554821 module?
DontTaseMeBro
There are several other part number that preceded 13554821. Yours might have 13537053, 13544060, 13544950, or 13545846. My guess would either 7053 or 4821.
StephenPT
St. Helens, OR
Crawl under the left side of the frame and with the right angle of view you’ll be able to see the part number without removing it from the frame.
J
jfoj
The build date on my truck is 8/2024 so assume it is likely the 4821 module. Will try to check later today. Was all under the truck a few days ago permanently installing my Park Release cable tool. So I at least can force the transmission into neutral if I ever need to move or tow the truck. Hopefully I will never need to use it, but at least I will not need to crawl under the in the rain or snow and worry about the truck rolling over me!!!
DontTaseMeBro
So I ordered one from Shea and one from Summit Racing. Shea just emailed saying the following "I am processing this order and wanted to let you know that I do not have the fuel pump control module in stock. I can have it from our GM factory warehouse in about 1 day, so this order will ship tomorrow. Please reply to this email and let me know if I should get this order started for you."
I'm not holding my breath.
a1parrothead
