Spare FPCM (Fuel Pump Control Module) WISE IDEA!!!!
jfoj
A word to the wise, I would HIGHLY suggest anyone what owns even a newer (2021+) Tahoe/Suburban/Yukon, Sierra, Escalade to purchase a spare FCPM and keep it in the truck. Even if yours has been replaced under the recall or due to a prior failure or even if you have the latest part #13554821 it may save you from being stranded as well as a lot of out of pocket expense and delays. From the quick research I did, it appears both the Gasoline and Diesel 2021+ trucks and SUV's use this same module part number or at least this later superceded part number.
Not sure what the real going rate for the latest version #13554821 FPCM is, but I found a new one online at a GM dealer for $51.92, with shipping and tax it was in my hands for under $65. While searching I was finding many dealer showed they did not have this FPCM in stock. I wanted to get one of these modules in my hands ASAP as I am a road warrior and typically make regular 2-6 hour trips and wanted a spare module on hand in the truck.
There is a LOT of information/mis-information running around on the web that indicates that this module needs to be programmed for the 2021+ trucks and SUV's. Well I just did a test, I connected up the new, replacement module and when I unlocked the trunk the fuel pump powered up without issue. Truck started and ran fine. Allowed truck to run about 10 minutes, then turned truck off and connected original module back up and truck started up and ran fine! I DID NOT disconnect the battery for this test as I wanted to emulate what I would do if stuck on the side of the road and wanted to get the truck running ASAP. I think part of the confustion about programming is with the 2019/2020 and earlier trucks with the FCPM that has the connector that plugs into the side, rather than then the end of the module did require programming. I found this #13554821 DID NOT require any programming on my 2024 Yukon.
I did find something online that indicated you could power up the vehcile (Service Mode) but not start the engine, wait 2 minutes, turn off for 2 minutes prior to staring the engine was the procedure, but I did not do this because I heard the fuel pump power up upon unlocking the truck.
On my Yukon the module is on the frame rail under the driver side rear door. I have heard on some models this module may be in front/on top of the spare tire???
I put the replacement module back in the box with some wire ties so I can temporarily hang the module until I have the time and place remove the bracket from the frame and swap the module propertly. I put the box with the new module under the rear cargo floor for future needs, either for myself or friends/family or possibly a stranded fellow truck owner on the side of the road.
Given these module are 3 phase inverters, they will not last forever. Just look at the HVAC industry and all the failures of the variable speed fan controllers!!!! While GM may even upgrade the #13554821 module at some point for greater reliability, I would rather have a good, funtional module in my truck for when this module leaves me stranded on the side of the road!! Usually when I am proactive and have spare parts that often fail, I often do not need the spare!!!! If the FCPM ever fails while I have the wife in the car and tell her to wait 5 minutes while I pop the rear tailgate and crawl under the truck this is well worth the small investment. I might even be a hero for an hour!
For the $65 I spent and how easy it is to swap the connector to a spare module, this is a real bargin as well as a good piece of mind for unintrupted travel.
DocDoug
Thank you for posting regarding the fuel pump module. I have been looking for a spare one too to keep in my glove box. I have called everywhere and even looked on a few websites with no success. I am getting ready to do a 3k road trip. Where did you find your OEM replacement? Thank you in advance!
J
jfoj
The listing did not say they had it is stock, but the price has even dropped about $3 since I purchased mine. Good luck, I hope they can get you one in time for your road trip.
I also have a transmission park release tool coming from a different source. This appears to be able to be permently bolted to the side of the transmission. Not sure if I will try to route under the dash or under the hood!
I hope you have an uneventful and enjoyable trip!
Update the thread if your order is fulfilled. I actually purchased another one from a different site that is backordered. Figured why not have 2 on hand!
DocDoug
Thank you. Used code "MINUS10" for 10% off. Ordered, $55.16 to the house! I will advise when I have it. Thanks again!
J
jfoj
Can't refuse a deal like that. If everyone had a spare think about how quick you could be back on the road. Only thing better if there could be a redunant standby that automatically switched over!
PMed most of the DC brush style fuel pumps in all my cars as it is not worth getting stranded. On my 2005 Yukon swapped the pump out at about 10 years, probably needs it again at this point!
B-train
For a 10 minute change, did you make an access door? I have 195k on my 2008 and I have a spare pump that I ordered, just haven't grown the balls to cut the access panel as of yet....
J
jfoj
I was spoiled by all the German cars that had 3-4 bolt access doors under the rear seats. I dropped the tank when I had to replace all the metal brake lines. I got very nervous because I knew I was on borrowed time with the brake lines. When I dropped the splash guard under the drivers footwell one of the line had just started to seep!
Almost every vehicle built in the US between 1998-2005 had crap, non coated steel brake lines. The painted line that was on top of the rear axle looked like it just left the factory at year 10! I have had to replace lines on a bunch of trucks and every Buick in the family!
blanchard7684
Senior Member
Yep I picked one of these up as a spare. cheap insurance and easy to replace.
Although it looks like the FPCM failure rate is waaaaaay lower with this current part number than others.
DontTaseMeBro
Ok so what happens if this thing fails? No start? Engine dies? First time hearing about this.
Marky Dissod
J
jfoj
You walk and have to find a way to have the truck towed. If the engine does not start, you cannot get the transmission out of park. The park control in the transmission is hydraulic. If you find a knowledgable tow company they can override the park problem, but they also need to disable the parking brake. Some may take the time, others may not want to deal wit the problem.
If you have a spare module, 5 minutes, no tools and you are back in business.
Some of the 2021 trucks had a recall for this part. I belive the part number has been superceded a few times.
Either way, I would not trust the FCPM to last the life of the vehicle, much less 5-6 years.
But again, if I buy a new snowblower, I would probably not have any or enough snow for 5-7 years to need to use it!!!
Cheap insurance, even if you do not need it, you could help a stranded friend, family member or complete stranger. I have 2 in my truck!
DontTaseMeBro
Holy cow, that's crazy. I'm surprised there isn't more discussion on this issue. I'll be on the lookout for a new spare.
KMeloney
Actually, there IS a decent amount of discussion about this here, since a number of the crap-outs some folks have reported experiencing and believed to be total engine failures were actually the failure of this part. But, yeah, there weren't too many threads started specifically about this subject.
My mother's '09 Caddy DTS with less than 50K miles on it had this fail on it last summer. Luckily, the car was in the driveway and wouldn't start (vs leaving her stranded on the road somewhere).
I just ordered one of these. Thank you for this thread, all!
J
jfoj
Along with keeping an OBDII interface in the vehicle for use with the OBDFusion App on my phone, I have and will be installing and hopefully be posting a thread on adding the Park Override cable for being able to put the transmission in Neutral when the engine will not start/run or there could be a problem with the transmission generating fluid pressure to release the Parking pawl. You also need to bypass the electric parking brake in this situation as well unless the battery is dead or disconnected. Oh the fun Easter Eggs the design engineers leave for us to find!
Sure you can climb under the truck to bypass/release the Parking pawl, but this can be unsafe and could also get messy depending on the weather. I look at this as adding the Park bypass that should have been included when the vehicle was built. Other brands have ways Park can be bypassed from inside the drivers compartment.
Forgot to add that you may want to keep a few contractor trash bags in the rear storage compartment if you need to lay in the mud, snow or on wet pavement to replace the fuel pump relay. Or if you have a rear cargo mat, you can pull this out and lay on it when you crawl under the truck.
PPV_2018
Molon Labe
U.S.A.
Yea, there actually is a decent amount of discussion regarding FPCM failures on the newest gen of our trucks. So is this really only any issue on 21+ or… what..?
Do i need this spare part for my K2 or not really ..?
KMeloney
Again, my mom's '09 DTS's crapped out without warning last year. My mechanic told me that these units have been notoriously prone to failure for years now. So... Maybe probably?
J
jfoj
I am not really familiar with the K2 platform. I know some of the prior generations did have issues, some with water intrusion into the connector especially if they trucks were used at boat ramps. Some did have FPCM failures.
I also believe this generation required the module to be programmed, so if you do get a spare, test it and if it does not work, get is programmed so you have a functional spare.
I look at anything that typically would leave you stranded and you cannot buy parts within an hour at an auto parts store or Walmart (Battery as example), then having a spare that has questionable history is a wise idea.
KMeloney
Just received an email notice that my order had been cancelled, that the item is on backorder. Dangit.
J
jfoj
Some dealers will allow an item to stay on open back order status. Some dealers cancel the order if the part is on back order. I have a different part on backorder via a different dealer source and they emailed me and I had to decide if I wanted to cancel the order or leave it in back order status. In this case, I left the part in back order status as the part should hopefuly be available in late January??
I put an order in for a 2nd FPCM via a different dealer, they came back and indicated if was out of stock, but then a 10 days later I received shipping notification.
Again, search around, you may have to pay slightly more for the part and/or shipping, but some online dealers have the part in stock.
BadDaddy2003
