iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 1,125
- Reaction score
- 569
Alright. I hear those are a bit more difficultYes, absolutely. Than, you will have a good full set of shocks and be all set for the next 100k miles.
If it were me, I would not ride without shocks, as there is too much risk of something unexpected happening. Plus, the front shocks are an integral part of the supporting suspension and the truck cannot be driven without them.Is it OK to ride it without a shock for a few days it’s supposed to be here tomorrow Monday. Probably do it Tuesday. Maybe Monday afternoon if the weather is decent. I mean, I’m sure they were serving no purpose anyway.
Just 'cause you CAN, don't mean you SHOULD.Is it OK to ride it without a shock for a few days it’s supposed to be here tomorrow Monday.
Probably do it Tuesday, maybe Monday afternoon if the weather is decent.
ImIf it were me, I would not ride without shocks, as there is too much risk of something unexpected happening. Plus, the front shocks are an integral part of the supporting suspension and the truck cannot be driven without them.
The choice of replacing the entire front strut assembly versus replacing only the shock is a matter of personal choice, but it is not necessary. Keep in mind that if you purchase only the shock itself, you will need the services of a powerful spring compressor to compress the spring to disassemble and re-assemble the strut assembly. Although it has been done by some folks, I definitely do not recommend attempting to disassemble the strut assembly using standard spring compressors designed for car springs. A local repair shop has the equipment to quickly disassemble/re-assemble the strut assembly to replace the strut, and I strongly recommend that you proceed in that direction, if you plan to do the overall job yourself.
Less body roll and less bounce. Could just be me.Let us know if you feel an improvement after the replacement.
Is it less bumpy now than before? Are you on stock wheels?Less body roll and less bounce. Could just be me.
See I was replacing the shocks to hopefully mitigate the stiff ride, but it seems like these SUVs just have a stiff ride you know? It seems like they’re not really made for off-roading and bumps, but more for long stretches of highway.Is it less bumpy now than before? Are you on stock wheels?
Mine rides similar to how you described at the beginning. Like you I got it later in it's life without knowing the suspension history. It also came with a set of 22s which may or may not be apart of the problem. It's not a terrible ride but it always has this slightly "unsettled" feeling, especially at slower speeds. It's still solid and comfortable overall though. I would have to ride in another truck to see if it's any different.
I replaced shocks on a 95 Maxima in the past that had a lot of bounce and it solved the problem. I did the same on an 04 Maxima that had a bumpy/harsh ride and it didn't. Not saying the shocks didn't need replacing due to mileage but the bumpy ride was unrelated to them being old.
If (for whatever strange reason) you find your ride too stiff,... replacing the shocks to hopefully mitigate the stiff ride, but it seems like these SUVs just have a stiff ride you know?
Want more absorbing for the ****** roadsIf (for whatever strange reason) you find your ride too stiff,
then you should very seriously consider less-stiff coil springs.
'How much less stiff?' would be the question you'd need answered.
censership is so funking we tardidWant more absorbing for the fukdtup roads
How do you lube a bushing? Just slather some grease on it?censership is so funking we tardid
If you do NOT care about improving handling, then
stay with 17" wheels, but if you can find LIGHTER 17" wheels, get 'em
replace your GoodYears (good for a year, as in, one good year ... get it?) with tires known for better ride quality,
like Continental TerrainContact H/T or Michelin Defender LTX M/S2, and don't pump them up past 36psi (under 30psi is a dangerously BAD idea)
very seriously consider 255/75R17, or 275/70R17 - taller sidewall will better protect against faulty asphalt
replace and generously lubricate every rubber bushing, eventually including the body-to-frame bushings,
possibly adding cushions to your suspension
make your vehicle lighter using parts from a hybrid Tahoe
