26x10 or 26x10.5 on lowered suburban. What offset/et
jordan11
I have 24” reps right now but looking at 3 piece 26” wheels. Anyone with x10 or x10.5 wheels? What et are you running? I don’t want wheels sticking out past body.
Doug118
On stock suspension, any x10 should be fine. 10.5 might be okay in the back with a smaller tire. If you’re lowered more than like 3/4, you’ll most likely get into rubbing issues up front
This is a 26x10 +31 with a 305/30/26
Doug118
This is with a 295/30/26. Front fenders are pulled. Rears have the fender lip cut off. Not sure how much you’re lowered but this is pretty much the extreme as far as static with big wheels goes. Wheels hit the firewall pretty hard and made it a nightmare to make even somewhat tight turns
Doug118
In my opinion, if you’re ordering something custom, I’d go like 35mm up front and like 30mm in the rear. That also depends on how small of a tire you can run
This is a x10 13mm offset with a 275/25/28 just for reference. The fronts would stick out way past the stock fender
J
jordan11
Those are all a bit too close to the fender for me. Also wondering if last gen and this gen fit the same.
J
jordan11
The wheel company emailed me some specs, 26x10.5 et 26, not sure if that’s good or not. I really don’t want any rubbing anywhere. This is what I was looking at.
KMeloney
You're looking at two gens ago... And no, they don't fit the same.
Doug should be commended for trying to help, but the backspacing between the last two gens and this gen is different.
jgraves
I've gone in a completely opposite direction with wheels and tires (315/70R17 on 8.5 ET18), but I would be concerned about a 10.5 ET26 rubbing the upper ball joint. I have very little clearance there with my setup, and even the OE tires are close. For reference, OE are 20 (optionally 22) x9 ET28. The above are 38mm wider and only 2mm less offset, so 17mm closer to the ball joint, everything else being equal. With a 26" diameter wheel, I don't know how much a comparatively narrow tire will help.
Jeff
BadDaddy2003
