Anyone install JL Audio stealth box?
ACEC7Z
Has anyone installed the JL Audio stealth box in their Tahoe or Yukon? The BOSE system is fantastic and the factory "sub" is alright. Just curious if the single 10" provides enough bump to justify the cost.
BrokerThis
'22 Denali Dmax
Detroit
Seems like he hasn't posted much since then. Page 4 shows swapping to escalade box for drastic cost savings
carlsonsteve
Lighthouse Point, Florida
I've had a 10" JL Audio Box in my 21 for a couple of years. The guy who wired it for me did a terrible job tapping into power in the rear jack hatch. I'm redoing the whole install this week up to the front battery. I'm using a 500 watt mono JL Audio amp (RD500/1) and JL Audio's 2 channel line output converter (LoC-22).
The addition of the sub system gave me exactly what I was looking for with the additional low end and punch. Amazing result.
GTPace500
The BOSE system is abysmal, at best. It's muddy no soundstage and lacks any kind of feeling to it whatsoever. The ELS system in my Acura MDX is miles ahead, and that's from 2018.
ACEC7Z
ACEC7Z
Thanks for the reply. I'll probably look into this exact setup. Do you happen to have any pictures? I'm curious where you placed the amp ... Thanks.
Spacewrangler
I installed the JL Stealthbox, JL XD300/1v2, AudioControl LC2i PRO, and John at Audio Integration Solutions’s wire harness to tap into the existing BOSE system harness.
It’s crazy how much bass a single 10” sub added to the system. It’s a pretty straight forward install assuming you’ve installed car audio previously. I installed the amp and LoC in the shallow storage area in the cargo compartment. I routed the LC2i knob right next to the USB ports right above the wireless charging pad. My only recommendation is that depending on how you want to route your amp wire, you’ll probably need 25ft on the 4 gauge wire. I thought I could get by with 20ft, but came up short by at least 3ft by routing it back across to the driver side in the engine bay.
undertaker
Long Island NY
Just curious on who makes that harness, have a link or contact info for that John at Audio Integration Solutions? didn't turn up anything with google.
Spacewrangler
He doesn't have a website as it's just a side job for him. I just emailed him at [email protected] and gave him my RPO code list so he could make the right harness.
ACEC7Z
ACEC7Z
Awesome thanks for the input!! Think I'll end up getting almost identical setup.
Boosyed96GSX
Orlando, Fl
Hey, could you clarify what kind of harness you had made from John? I’m looking to add a stealth box to my suv and want to track down all the parts before the box gets here. I have the amp kit, amp, and stealth box. I’ll search an LOC next but was curious what the harness you used was for.
Also, where exactly did you hid the amp? I was hoping to put it near the stealth box itself and minimize running wires all through the cabin.
iamlegion
There’s another thread where a couple of us posted pictures on this including myself.
There are harnesses to grab the amp speaker outputs and send to LC2i. I used the sub high level lines, some who don’t have the higher end Bose may not have a sub to tap into.
There are also harnesses you can plug inline to the rear amp that disables the ANC microphone so you don’t get a hum and don’t have to cut the harness.
Boosyed96GSX
Orlando, Fl
Thanks, I’ll see if I can find that thread.
Do you have a website to the harness(s) needed?
iamlegion
Make sure you get your radio RPO code correct.
If I could do it all over again, I would have modified the ANC bypass harness with a switch. Sometimes when I don’t need the sub - like on road trips with the family I would have liked to be able to switch the ANC microphone back on and the sub amp off.
Kpwweb
I did not install the JL Stealthbox, but instead the Cadillac Escalade sub box, a 10” Audiocontrol shallow sub, a 500w kicker mono key amplifier, an LCi2 speaker to line converter with harness, and ANC microphone harness. It is amazing the bass retored by the 10” sub. Went through the key setup process to restore lost bass. Love the setup.
I looked at the Stealthbox, but could not justify the spend for the squeeze. Just offering an alternative here.
To each their own.
john1989
