Alright. First round up updates. I was waiting on the last of the parts. RockAuto decided to send me rear rotors with the front pads..and front rotors with the rear pads
Updates:
- Replaced parking brake shoes.
- Replaced rear brake rotors, pads, and hardware.
- Bled the calipers while pushing in the piston to make sure I get all that gunk out of there and not back into the system.
- Glad I did, because I exchanged all the brake fluid in the revisor. That stuff was dark!
- Exchanged the power steering fluid, figured I can since I was under the hood. Solved the power steering fluid noise I heard while starting up the car.
- Performed the burn in procedure for the rear pads
- Hill tested the parking brake. All good there.
Pictures attached of the vehicle and the dark brake fluid. Darkest I’ve ever seen brake fluid, can’t wait to do a brake flush.
Next up:
- Front brakes and rotors
- Front upper control arms
- inner/outer tie rods, need to check if I have to rent a tool. If so, I may push this to next week when I go into town.
