Budget rebuild items?
Charlie207
Charlie207
LFOD, New Hampshire
No Summit, thank you.
VEGE BU60FHD (fixed typo)
Charlie207
Charlie207
LFOD, New Hampshire
Long-block installed:
All accessories installed.
Installed updated BBP tune, but am running into persistent P0010 (cam sensor) code. Assume it has to do with the VVT-delete, and am hoping a revised tune helps deal with that. Perhaps they have to disable the CEL for a missing cam phaser error, to prevent the issue.
Also seeing ABC/TSC lights on dash. I've checked both front wheel speed sensor connectors, and they look good. Some googling has shown a common P0010 & ABS issue after a cam swap/VVT delete, so I'm not sure.
I've been able to sporadically fire the engine with the 6.0 basemap, and it's a pretty lumpy idle. However, after the engine warms up it won't restart.
Charlie207
Charlie207
LFOD, New Hampshire
Hey now... they sent the revised tune. It addressed the cam idle quality and P0010 error message deletion.
After flashing the tune the engine fired right up, and restarted every time I turned the ignition on/off, after letting it idle for a while to come up to temp, and cycle the fans.
After the only work call I have to actually attend each week at 4-5pm I'm going to button up the body panels, and go for a rip. (fingers crossed)
Charlie207
Charlie207
LFOD, New Hampshire
Buttoned most of the stuff back up (minus the splash guard/skid plates) and went for a short drive to get everything up to temperature. Nothing blew up, and everything seemed to work. When I got home the ATF was up to temp so I could check that level, and it was low enough to use up the quart of Dexron-VI I had laying around, so I'll have to limp down to the local parts store to get some more.
Charlie207
Charlie207
LFOD, New Hampshire
Current issue is that the ABS, TCS, and Brake lights are blaring in my face. I've checked the two front wheel speed sensor connectors, and they're tight.
I don't see anything obvious, and am worried that I may have inadvertently cut, crushed, or yanked on a wire or harness while removing/replacing the engines.
At least my oil pressure is higher in this engine.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I don't, but my friend (a full-time mechanic w/huge garage bay & lift at his house) has a SnapOn (FapOff?) scan tool.
Is it driving funny? Any noise or vibration from the ABS kicking in?
Charlie207
Charlie207
LFOD, New Hampshire
No. When I close my eyes while driving down the road it feels the same as before the engine swap.
The brakes feel the same, aka normal, when I press them easy or hard. I had to re-bed the pads/rotors because they got that this surface rust from sitting exposed through some rainstorms while doing the engine swap.
Charlie207
Charlie207
LFOD, New Hampshire
So, you have no experience? Unless you have a friend with experience, you may be spending extra “trial and error” resources on this project, i.e. special tools, incorrect parts, labor time. This is not your grandpas chainsaw. Not to mention a shop for all this fun to take place.
The engine is at almost 8000 miles, and running great with no leaks or incorrect parts blowing up.
scottd
