BCM and Tech2
BattleTank
Senior Member
For those that have Tech2's, what all parameters can be changed on the BCM on a 11 Tahoe?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
That is the most non-constructive, vaguest answer I have ever seen on a forum.
What do you mean? It's the blower fan running after turning off the AC compressor to dry the the evaporator and housing out. I do it manually on mine. Some trucks can be set to do it automatically. I just did this a few hours ago when I ran out to lunch. When I got close to back to work I switched the AC button off to allow the blower to dry the housing out some. Keeps it from getting moldy smelling. I do it for the front and rear units both.
B
BattleTank
Senior Member
What do I mean? Someone SHOW me where any of this has anything to do with my original question?
j91z28d1
oh, I thought everyone knew what that was. it's a mostly useless function you can turn on to run your blower fans after your car is shut down for about 30mins.
I found mine didn't act anything like it's described, running the blowers over over again for 5 or so mins at a time, after the 3rd cycle of max front and back blowers running I reached up and turned it off. I was worried it would kill my battery in the middle of a road trip. being a hybrid jump starts are risk you really shouldn't take.
my driveway is steep and it holds a ton of water in the evap. in the middle temp time of year where it's not 115deg or cold enough to not need the ac it can get musty. turning afterblow on is meant to dry it out, but it didn't do anything for the smell anyways. backing in or turning the ac off a block from home helps.
I'm pretty sure that's the only option on these trucks the tech 2 can turn on or off?
my c6 I can walk thru all kinds of setups, select different suspension options for active or passive. pick the sound system type, if it's a bose or not. these trucks just go by the vin.
my bad
97YukonNZ
Thanks for the informative read you guys
My beast is a pre 2000s dinosaur by context.
It's is cold winter here and I find using the ac with heat clears my screen faster.
After stopping depending on ground level I get run off from it.
I haven't had any mould smells internally but will start doing as @89Suburban mentioned he does. Think will help maintain the system.
mikez71
Really not much.
Btdieselworks.com AutoSync w/ BCM programming the only real option. ($400)
The tech2 is a diagnostic tool for the most part, you can't really "modify" things with it other than the afterblow as mentioned already. If you have the digital HVAC control you can make the outside temp display on the HVAC control panel and you can adjust tire size.
Those are the only "user" adjustable things that I am aware of. The rest is all test functions and relearn various modules/sensors, and lastly calibrations as a pass thru device if that is even still supported by techline anymore, some have reported it takes special access by gm support.
petethepug
Michael
SoCal
Afterblow, NBS, NNBS, DIC, etc. Manufacturer specific anachronyms that all the long term owners are used to. We forget these vehicles are lasting 2-3x as longer than GM expected and some of these $86k vehicles are being sold for $14.5k (that’d be my Esky lol), and still reliable with another 200k left in them.
That’s a solid referral on the BTdieselwork OBD programer. 295 for the unit and 395 for the version with the engine & trans tune, which I regret not getting.
The best way to get up to speed on the Tech2 is you tube videos. All of GM’s secret unlock features are found in the BTdieselwork module.
petethepug
Michael
SoCal
That is a Gem! 154 pages of goodness
U
a1parrothead
