donjetman
- Joined
- Oct 22, 2018
- Posts
- 1,987
- Reaction score
- 3,641
Put the intake, timing cover, and oil pan on today
Its not Valvoline Premium Blue, It is Valvoline Premium Blue "Restore", completely different and off the market for yrs now. I got lucky and found someone with 4 gals they didn't need and bought it from them.@donjetman How long did you run that mix of VPB and oil for? Your results are pretty convincing.
I'm mistaken. I stopped by the local Cummins dealer in San Antonio, TX and they had 10 gals of it, $80/galIts not Valvoline Premium Blue, It is Valvoline Premium Blue "Restore", completely different and off the market for yrs now. I got lucky and found someone with 4 gals they didn't need and bought it from them.
you never know when your gonna need some, and you never know when they'll stop selling it, so I bought some, its quite unique.I'm mistaken. I stopped by the local Cummins dealer in San Antonio, TX and they had 10 gals of it, $80/gal![]()
In my stock 2007 Yukon Denali L92 no afm with 272,000 miles, I use Banks Automind to raise idle to 600 or 650 rpm. This raises idle oil psi from about 14 psi to 18+ hot. Makes me feel better.
Cold start oil psi is always 50+ at 55 degF and it is 35-40 psi from 1200-1500 rpm hot.
I use costco or walMart Synthetic 5W-30 and ACDelco UPF63R (vette?) Filters with oil changes about 7 to 9,000 mile's (10 to 20% oil life left per dic).
Bigger area and higher bypass pressure in UPF63R, is it helping or hurting in my quest to get to 350k miles?
I run it hard at elevation in UT, NV, and Co, off road a bunch, and carry lots of stuff, 2960 front and 3350 rear axle weights BEFORE I put the 340 lb. Moto and rack 2 feet back of the hitch.
for a long happy healthy engine life.Just spit on em, rub a little dirt on there and when double check the gap. They will be fine for another 100k.Are those Barnacles on the spark plugs
you saw the plugs that I pulled out, I cleaned them in my media blaster and ran them another 40kJust spit on em, rub a little dirt on there and when double check the gap. They will be fine for another 100k.
