Snapped Headlight housing clips
iboughtatahoe23
iboughtatahoe23
All attaching areas should be inspected. The attaching components on the housing and where they attach at in the hole where the housing sets. You could have an attaching piece that is fine but the housing could be damaged where the attaching component attaches at the housing. Or something is damaged where the attaching component grabs at the vehicle.
What I am trying to say is, you could install 10 new housings and never fix the problem.
Is there a way to do this without removing the bumper and splash shield.
iboughtatahoe23
iboughtatahoe23
I have a GMT800. I do not know.
There’s two 10mm bolts holding it on that you can see with just the hood open but I didn’t know there was a third on in the side that you have to pop the splash shield off for in the wheel well that is snapped clean off. At this point I think I’m just going to leave it. I don’t think it is affecting my light path. If it is I can’t see it with naked eyes.
iboughtatahoe23
iboughtatahoe23
Think it’s this piece?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Between the 3 bolts it should hold fine IMO.
To get to the bottom bolts all you got to do is pull the inner fender back and unclip the top of the bumper from the fender. It will give you enough room to reach in there for the bottom bolt. I was even lucky enough this weekend to pull the bumper down far enough to go straight at it with a 1/4" drive extension and 10mm socket. All you have to do is loosen it or tighten it no need to remove that bolt completely.
89Suburban
SE PA
I got these in 2019 for my 2010 and they looked like new when I traded in 2023. Came with bulbs and harness.
This is an excellent video showing all the fasteners.
I bought a set from them too. The first set took water vapor on immediately. I contacted them and they replaced them for free and told me to keep the old ones.
Recently went with these:
89Suburban
SE PA
They have a great library of install videos, they are my go to for that usually.
iboughtatahoe23
iboughtatahoe23
I watched that same video yesterday and tried to do it myself, and that guy in the video fails to mention that their screws inside the bumper you have to undo as well. It’s not just clips.
Did they make a driver side only version?
I see That carparts.com has driver side only
iboughtatahoe23
iboughtatahoe23
To be honest, I was just going to remove the empty second battery tray spot and then remove the washer fluid tank. I feel like that would be easier.
CrackerJack135
