2016 tahoe, how long do these fuel pumps last?
louu
South jersey
Hi guys,
I just got a new to me 2016 tahoe. It has 130k miles on it.
I also have a 2002 Silverado I've had since 2004 with just under 400k miles on it. I've had to put a fuel pump on that truck about every 100k miles.
Do these newer 2016 tahoe's still have fuel pump issues? I'm just wondering if I should change the pump before it leaves me startnded?
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
What @homesick said is soooo true. Think of 1/4 tank as empty. Also, the older ones have a separate fuel filter and too old makes the pump work too hard to push fuel. Also, the quality of fuel makes a difference.
As easy as it is to monitor fuel pressure, you can plan ahead because it will never break down in your driveway.
Marky Dissod
JIC, do you fill up at the 1/4 tank mark? Leaving that last 1/4 tank's worth helps cool your pump, which helps it last longer.
My '01 Tahoe went about 20 years on the original pump.
You must've changed your fuel filter pretty often.
You can't change the newfangled fuel filters without dropping the tank. Seems kinda dumb,
but then I remembered that, for GM , this is a great idea!
homesick
The Best Me I Can Be
Navy Air Force
In the 23 year life of that truck, that's the only time the tank's been dropped.
joe
louu
louu
South jersey
@homesick thanks bud. Not really, I drive a lot and usually run it down to an eighth or less. I understand how it works but I don't want to go to the gas station everyday lol.
@OR VietVet thanks for the welcome!
15burban
Wisconsin
If it ain't broke don't fix it. That's my opinion. It could go out tomorrow or it could last you another 130k. It's not really a "wear item" per se. It either works or it doesn't. And if you get lucky when it does go you might be able to bring it back to life a time or 2 by pounding on the tank.
My work beater (little 2 door pontiac) just rolled over 270k and I've thought many times about replacing the starter and alternator on it since both are still original and could leave me stranded. I could pop start it if the starter did go. But anyways if I would have changed either of them out like I really wanted too when I hit 150k. There's a possibility the replacement one would have went bad already. While the original is still going. Probably jinxed myself now lol.
Well, then, guess what, you have no one but yourself to blame when that pump has ran too hot too many times and konks out quicker than normally would
Pop start it? You mean jump start or you have a 2015 manual transmission Suburban?
homesick
Navy Air Force
There's just something about self-inflicted wounds.
joe
15burban
Wisconsin
Sorry I was talking about my 07 pontiac 5 speed.
He meant, pop start his Pontiac Sunbird or Sunfire or Firefly.
How much space do a starter and an alternator take up in the trunk anyway?
Yep it's a g5 but basically same thing. Being a 2 door and usually I'm gone all week for work (construction). I leave the back seats right out of it with how much stuff I bring with me. Suit case, cooler, sometimes a small grill, and then 200-300 lbs of tools and supplies.
dizhai
