Can I drop my differential safely with the cv axles disconnected or will my vehicle front end fall
mrs111180
Can I drop my differential safely with the cv axles disconnected or will my vehicle front end fall. (Swayber disconnected, cv axles disconnected
Charlie207
LFOD, New Hampshire
I have a spare front diff to swap in, and all the how-videos I've watched in preparation show the procedure straightforward, just heavy.
If the diff weighed 20lbs instead of ~95lbs it'd be an easy job.
Just Fishing
Can't fix stupid
Utah
I use a ratchet strap to scrunch the cv axles in after it they are unbolted from the diff.
From there it's a straight drop down using a floor jack.
I have done it more times than I can count at this point. :jester:
R467X
I've dropped mine a couple of times. Couple of suggestions:
Fully remove your CV axles. It'll require you to also take your struts off. Pretty straight forward. Gives you room and saves time when it's time to bring it back up.
There's also a frame bar (sorry can't recall the exact term) sits closer to the back and goes across the middle. Remove that. 4 bolts 2 on each side.
I highly recommend a tranny jack but it's totally doable with a combination of a regular jack stand under the pass side and a regular jack. You might have to move it around it's not going to be a clean drop/bring back up. Ideally a 2 person job.
BattleTank
Senior Member
Are you also saying remove them from the hubs too? I've heard this is bad for the bearings.
R467X
Yes. You won't damage the bearings by removing the CVs. I just did my AFM delete and had to drop the oil pan. Tried bringing the diff up and ran into fitment issues that eventually required me to remove the CV axles to get the diff in the right spot to bolt on. I guess it isn't necessary but when you're Jerry rigging it up with a jack / jack stand, there isn't much mobility. Just makes it much easier when things are off.
R467X
Also don't forget you'll have to disconnect the smaller drive shaft driver side from the diff and there's a vent line that sits up top that'll need to be disconnected too.
BattleTank
Senior Member
I've just head a lot of stories with the S10 group when they remove the CV not to remove the shaft from the hub.
R467X
I've done that so many times with zero problems when doing suspension work. My diff has been dropped 3+ times for various reasons. I've probably re-done taken things on and off my suspension 5+ times since 2011 between lift kits combos and suspension wearing out. Only replaced hub assemblies twice due to mileage (268k). Just make sure everything is torqued to spec with a torque wrench and torque the cv axle with the wheels on and vehicle on the ground once you finish (also when you bolt them back to the diff make sure you torque them in a star pattern (like you'd torque your wheels)to the diff, can use a screw driver inserted in the rotor for leverage)
Also if you do remove the cv axles, make sure they are completely unbolted/freeish from the hub before taking the strut out. Don't want to hyper extend them, ask me how I know.
But like I said, you don't have to take them off the hub. It just makes things much easier. Especially if you're on your back by yourself.
a1parrothead
