ARP Valve Cover Bolts
AmunRoo
Chicago
Hey Y'all!
I had a curious question. I ordered a set of ARP valve cover bolts. Part number is 100-7523. Not really too sure if I needed more parts for them. But my question was if anyone has had any experience with them. Have you bought them and not installed them because you couldn't figure it out either or did you buy them and install them? I'm still a little stuck as to how the would work. It comes with the eight bolts and 4 metal washers which technically don't work with the stock valve covers. I just finished replacing my head gaskets and I thought I'd go arp all the way well, as far as I could go. And now I'm stuck. Any and I'll help is greatly appreciated!! I also bought a billet alternator bracket that also holds the power steering pump. Definitely like it a lot better than the stock look.
tooleyondeck
Northwest FL
I have not used these, but after looking into them it looks like washers go over the rubber grommets on the VCs so you'll need to reuse them as well as your stock spacers from the stock bolts. I don't see a benefit to this unless you're running a ton of boost.
Charlie207
LFOD, New Hampshire
Hey Y'all!
Where did you find that billet alternator bracket?
scottd
