So I finally changed my plugs and wires.
iboughtatahoe23
Bought them last summer and just now getting to them. I have a few questions. It was a pretty easy but I noticed some of the plugs tips were ashy red, some were ashy white and some had oil on the threads. At 175k my dad keeps saying it’s normal for high miles. Need a second opinion. I was gonna hit the o2 sensors next.
In this photo the plug has all three symptoms: oil, white and red ash on tip.
j91z28d1
I'd have to Google what the red tip is from.
that plug is rough, but also no telling how long it's been in there. I would put a catch can on it soon and check whatever the worse plug was in the next 5k to 10k miles to get a feel for how bad the oil burn is.
does it at least run better with new plugs?
iboughtatahoe23
iboughtatahoe23
Yea seems to be running a lot smoother and even shifting a lot smoother. Idk how to explain but the acceleration feels much smoother and not as rough or uneven if that makes sense. The nice gentleman who was nice enough to show me how to change my plugs and wires says it could just do too high mileage, he thinks the red tips might be from E85.
mikez71
red color I thought was fuel additives. Google (Rick's free auto advice) tells me it's a type of octane booster..
Octane booster causes a red tint on spark plug electrodes and insulator discoloration
If a fuel additive contains an iron component, it can cause red deposits on the insulator nose, center electrode, and side electrode. The iron coating is electrically conductive and can cause misfiring.
iboughtatahoe23
iboughtatahoe23
Man that is some big gap, how many miles are on them / the vehicle?
174k and those are pre gapped. I think they are the same plugs that are in 2010 Camaro.
I replaced them with ones for the Tahoe Instead which are also pre gapped from factory. Either .35 or .40mm I believe. I could be wrong
iboughtatahoe23
iboughtatahoe23
Right and there’s no telling what the owners before me were running or if they even changed the spark plugs and wires at all. So I guess time will tell. I’ll run it for about 10 or 15 K and then pull one of the plugs and see what’s going on.
tom3
Any problems getting the old plugs out? Sometimes they just don't want to come out seems like. Put anything on the new plug's threads?
Probably 0.040 INCHES and not mm. .40mm would be hardly any gap at all, 0.016".
iboughtatahoe23
iboughtatahoe23
I didn’t use any antisieze. Or anything on threads. They came out easy and went in easy. I turned them until they tighten and than one More crank for good measures. I used the dielectric grease on the wires.
iboughtatahoe23
iboughtatahoe23
Many spark plug manufacturers don't recommend using antiseize, since the thread coatings are made to do just that, and it can alter the torque applied when installing (which could cause thread stretching or failure).
Yea that’s what I was reading. They say to reduce torque 10-15% if using it.
iboughtatahoe23
iboughtatahoe23
I will add that if you’re not sure about doing
Your plugs and wires. Do it. It’s easy. Just do one at a time. I don’t think you can even really mess the firing order up on thess LS engines bc they have individual coil packs. You’d have to really not be paying attention to mess this job up.
GlennSullivan
Westchester, NY and Jupiter FL
Unless it is the angle of the picture, what I'm seeing is way more than .040. Oh and by the way, don't believe the "pre-gapped" B/S. I did my Z06 Corvette last winter and purchased "Pre-Gapped AC/Delco plugs and the gaps were all over the place - supposed to be .040.
Gearz
The top end of my 5.3 was not feeling like it was getting enough gas like getting on the highway so at 130k I replaced both pre cat oxygen sensors and the engine woke up like crazy. Oxygen sensors do have a life span and will slowly die without a check engine light. Give it a try if you feel like it’s low on power or your over 100k and you will be surprised what happens!
enginehead
I changed the plugs on my 2010 5.3L back in September, it had about 135,000 miles. not problem getting the plug to break loose, only issue was accessibility on the passenger side rear 2, got a little tight, but I am a mechanic and was doing it on a lift and found going from under the engine was easier. I didn't put anything on the threads when I went in either.
only time I have seen spark plugs stick is in Ford engines, or with people who wash their engine regularly and the spark plug oxidizes to the head. you know, steel spark plug, aluminum head, different metals having electricity travel through them causes problems when they have water added regularly.
iboughtatahoe23
iboughtatahoe23
Noted. Where are all o2 sensors located ? I’ll look for the pre cat sensors.
Gearz
Pre O2 sensors are up next to the exhaust manifolds and the post are after the cat converters. Pre will have to do with drivability not post. Post is only used to monitor the converters.
curbud
