Show off your 2015-2020 lowered tahoes and yukons
olyelr
Elk Rapids, MI
Does anyone have issue if bouncing rear end after Tonys 2/4 drop kit. My rear end is hard. I know autoride shocks are still good but its getting worse after 2 years
Just because the air portion of the shocks is working, doesnt mean the actual shock is not worn. Bouncing usually is the shocks. If you push up and down on the bumper hard, there should be no bouncing.
Are you riding on the bumpstops by chance?
Slow5.0
Missouri
Not even close. Its just stiff on the back
Im thinkin if i over torqued damn bolts/nuts 9n lovering kit since i have problem making shit tighter than should be lol. But all the bushings on lower control arm and on shock should rotate even if i over tightned
Maybe rear shock are bad. Thinkin swapping for non autoride shocs since i have delete kits from ShockSims but never installed them
olyelr
Elk Rapids, MI
I wouldnt. But thats up to you. I loved that feature. If its still working and not giving you trouble, i see no reason to abandon it. Unless you are looking for way better shocks that dont have that feature.
Slow5.0
Missouri
Magnaride shocks were all bad. All 4. Leaking bad. Installed Arnott SK3353 front and AS3066 rear shocks. This fixed bouncing problem. Also vibration on 70mph is also gone. Yukon ride just like it did in 2016 when i bought it new. No more stupid seized up magnaride shocks
NR_RAILNPUP
Just completed my 2/4 drop in my '17 Tahoe. love how it came out just has a little rubbing on the inner fender well plastic. 26x10 +24 295/30/26
MrMonte
I don’t see a monte but i do see a 70 split bumper in the garage ;)
Sadly my 1971 Monte Carlo SS454 was stolen from me. I tried replacing it with a 1972 Monte Carlo 454 4 speed manual which was a fun car but never filled the void left behind with the loss of my SS454. Adjusted for inflation I had almost $20,000 in upgrading the engine. I was running 13:1 piston with water/alcohol injection.
I've owned 6 Monte Carlos and if I build another it will be a "1971 SS454 4 speed manual convertible". Rumor has it 10 Monte Carlo convertibles were built. In 1990 I looked at a 1971 Monte Carlo SS454 convertible that they claimed was factory with paperwork they were asking $10K for but left with $100K in medical bills from our twins I had to pass.
bradttu
Midland, TX
Long time lurker, first time poster. Wrapping up my 2019 XL dubbed 'Sinister'. 2/4 drop, 24" Dub Clout, hyper dip bronze badges, custom cut 'sinister' letters, headlights, taillights, painted calipers, MBRP cat-back, etc etc. I have a few more goodies left to do, but I'm happy with it so far.
joe_joe
View attachment 430950View attachment 430951
What drop kit did you go with? Did you keep the factory mag ride? Any rubbing issues with the 24's?
bradttu
Midland, TX
I am curious myself!
I'm curious myself!
MaxTrac 2/4, spindles and springs. No factory ride on mine. Zero issues with rubbing at all. I can lock the wheel in either direction and it's solid. Still has the factory ride cruising down the road. Bumps kinda suck given the smaller side wall, but that's to be expected.
ss4chad
Fort Worth, TX
Thanks man!
I am considering a 2x3 drop with 22's or 24's. What size tire are you running, 285/35 or something similar?
jkhuntzinger
