2-Channel Dash Cam Install
Lloyd Bonafide
Thanks a million! I followed your instructions and competed the install in 90 minutes. The most difficult part was fishing the wire through the door rubber conduit.
-Lloyd Bonafide
Salty821
Did anyone have trouble pushing the 2nd wire into the top of the windshield?
Chad G 1979
This was a great help to me when i added my dash cam last weekend. Took about an hour and half, but i was taking my time.
And yes i did have sone trouble with the 2nd wire going from front cam back to the side under the front edge of headliner. I just did the best i could and there is nothing showing unless you climb in and really look for it.
Thanks for the write-up.
WilFresco
Hey all,
Didn’t see any information on installing a dash cam in a 2021+ Tahoe/Yukon so figured I would share some info from my install for others.
Dash Cam is a VIOFO A129 Pro Duo that I picked up on a Black Friday sale. I also got the CPL filter and 3-wire hardwire kit.
Another thread stated F26 was a switched power fuse, this is on the passenger side dash . I checked all fuses and came to the same conclusion so I used F26 for accessory power and F44 for constant power.
A Micro2 fuse tap was used for F44 with a 5A fuse. I couldn’t fit a Micro3 fuse tap on F26 so just wrapped the wire around one of the fused legs of the existing 10A fuse (ie not the center leg).
Next I disconnected the + battery terminal so I could remove the A-pillar cover and not risk the air bag going off. To disconnect the battery, pop off the cover, loosen the nut with a 10mm socket, and pull the plastic tabs on the side of the batter to allow the entire fuse block assembly off the battery.
(Continued in next post)
Your walkthrough is great. I'm currently doing the same on my '23 Yukon and had a quick question. Are you saying you can use a micro 2 fuse tap on the f26 fuse since the power is supplied on the middle prong then the 3rd prong on f26 stays empty and wont cause no problems? i know this post was a little while ago but hoping to get some clarification
B
badreau
Alberta, Canada
No, you would need a Micro 3 fuse tap for F26, to retain the stock fuse functionality.
WilFresco
1 last question, on f44 for bat power, how u got the fuse tap in there? On mine the hot side is on the right prong so I’d have to put it the opposite way you did yours right?
1 last question. On f44 mine was empty but has constant power like yours, but in mine the hot side is on the left side, I’m assuming yours is the same, how u get the fuse tap on there, if I put it like you did, I don’t get power. What am I missing?
B
badreau
Alberta, Canada
Hey there. You had me scratching my head for a bit there figuring out what I did, but got it figured out.
Put a fuse of equal or larger size in the main/primary slot on the fuse tap. In my case I have a 5A fuse on the new circuit, and a 10A fuse on the primary circuit. The fuses operate in series, not parallel as intended.
What it is doing is passing power from the hot side, through the 10A fuse, to the load side, which then goes through the 5A fuse on your new circuit and you’ll have power.
fondupot
South Carolina
This thread was helpful. I got my BlackVue 590X 2ch dash cam installed over the last two days. It’s not the newest dash cam. But it works flawlessly with a power magic kit so it’s set it and forget it. I had it installed on my previous GMC Canyon for several years.
The front cam is easy. I used a Blendmount to attach the camera to the rear view mirror. It just clamps on and Allen cap screws hold it all together.
Then I ran all my cables thru the headliner down the passenger side A pillar. Took off that a-pillar trim and ran my wires behind the airbag. Down to the fuse panel area in the passenger side door jamb.
I used F44 for switched power, and a couple fuses up was a “not used” fuse for constant power. Seems to work nicely with the fuse taps I have.
Then I ran my rear camera cable down along the door sills all the way back to the trunk area. It’s easy to pop the sills off and tuck the wire in as you go. I didn’t have to buy and extension cable to get it back because the original BlackVue one was too short. I found one on Amazon, China special.
Once I got the cable to the trunk area I took out the rear floor storage compartment it’s held in with two plastic screw turns and lifts right out. Then I popped out the household outlet and the D-pillar trim and fished my wire up to the hatch. I used one of the accordion grommets to run my wires just like OP.
The only thing that’s annoying when the back glass is opened the wire for the cam gets pulled out. I left a loop on it under the trim so it pulls out easy. And it’s just as easy to tuck it back in.
All in all. A pretty clean install. Here’s a link to some photos.
Rev_Night
Hi all,
This is a great thread. I just got done reading it and would appreciate a second pair of eyes on my intended install. I plan on getting a BlackVue DR970X-1Ch Plus for our 2024 Chevy Tahoe. I do not want a camera on us inside nor do I currently need a rear one.
It will be mounted via a BlendMount BBV-2000R. Identical (i think?) to what was posted above. The default SD card will be replaced by a San Disk High Endurance 512GB.
To start, I turn off the engine and remove the + cable from the battery. This will prevent the airbag from deploying when I am screwing around with the A frame trim.
Attaching the blendmount to the rear mirror and snaking the wire down is easy enough but I'm sure will give me some troubles.
Once I'm at the front passenger side fuse box, I will put a Micro2 10A ACC in f44. I will use a Micro3 10A for constant power in f26. The ground wire will be placed "look around the kickspace under the a pillar". The OP used a 5A for f44, but according to pictures, its a 10A fuse, as is F26. So using 10A for both should be fine, right?
Anything else I should be doing?
Maryland
Thanks for this thread! It helped me install a VIOFO 129 Plus Duo dash cam on my 2024 Suburban.
I hardwired it using fuse 25 for BATTERY (always on) and fuse 26 for ACC (on with vehicle, stays on up 10 minutes after turning off vehicle or until you open the driver’s door), both of which are micro3. I used these fuse taps, which fit without modification! I replaced the included 15-amp tap circuit fuses with micro3 5-amp fuses. I connected ground to one of the nice grounds behind the kick-plate beneath the fuse box (as suggested above).
Maryland
Curious, why use Fuse 25 SEO/Upfitter? Someone posted earlier to use Fuse 44. Why the change?
Suburban passenger fuse box diagram:
Both fuse 25 and 26 are labeled SEO (for Special Equipment Option?). I interpreted that to mean it would be sensible for adding optional equipment, but not sure if I’m right about that, even if via a fuse taps hack. Anyway, I saw this suggested somewhere and those two fuses seemed to go together, so made sense to me.
Rev_Night
SEO in this context is Search Engine Optimization:
25Search Engine Optimization (SEO)/UPFITTER
26USB/Search Engine Optimization (SEO) Retained Accessory Power (RAP)
Maryland
Pretty sure those fuses don’t have any effect on Google search rankings! I think some human or AI did a bad job determining the acronym from the context and now it is all over the Internet. Hopefully that isn’t found in any GM documentation.
Rev_Night
ha probably
So I finally have time to work on this project. I am attempting to fit a Micro3 fuse to F26 and I am running into the same issue as the OP did -- it won't fit maybe.
I freely admit I'm a noob when it comes to electrical work. Does the orientation of the fuse matter? Due to its thick black covering, I cannot orientate the black covering going south because it will hit the big blue object. I can only orient it going north. Does it matter which direction I put the fuse in?
a1parrothead
