mountie
- Joined
- May 9, 2018
- Posts
- 5,525
- Reaction score
- 10,463
Good for those large size Cokes with the flimsy caps.....By far the best mod I have done to this truck!!!
YES!!! I ordered the larger option and it hugs my cups nicely! I'm excited cause we all know the stock cup holders aren't very good. I have been waiting on this thing all weekend!!Good for those large size Cokes with the flimsy caps.....
I ordered one from them and the one I received looked beat up. I returned it and got my money back. How did yours turn out?Replaced climate control in the hoe. This company sells you one and you send in your core, comes with lifetime warranty.
Automotive Scientific
Where did you find replacements?Replaced the cup holder flaps in the center console.
Did that myself in October 2022. The nuts under the dash are extremely tedious to remove and install.Replaced the hydroboost, I hope I don't have to do that again.
Ebay. I went with these as I was able to remove and reuse the center cap.Where did you find replacements?
Almost flawless, my old one had a chip on one of the buttons so I came out with a better one in the deal.I ordered one from them and the one I received looked beat up. I returned it and got my money back. How did yours turn out?
A high fluid level is a....... concern......What are symptoms of a failing torque converter? Most times putting it in gear, it's fine--but sometimes if I stop then go, or turn around a corner, it'll feel like it's in neutral. Sometimes I have to put it all the way in park, then drive and it'll be OK. The other day it felt like it went into neutral, so I revved it, then I heard and felt a thunk--going into gear I guess, then it was fine. There's no rhyme or reason that it happens--just randomly. I think it happens mostly when it's still cold. No weird smells, fluid level is good. Fluid level isn't bright red/punk, but it's not burned either. Trans doesn't run hot either--I have the Esky trans cluster. Anyone have any idea? I was thinking of changing pan fluid then throwing some Lucas in it.View attachment 423527
Shows a little over filled. Would that cause my issues?
